- Feb 20, 2007
Hello everyone,
Im starting to put down some ideas on my new gaming machine that I will be putting together and am looking for some advice on which mobo to choose.
I plan on overclocking to the top speeds that I can personally obtain, and make a bleeding fast gaming rig.
Here is what I have so far, any advice in general appreciated, but specifically trying to nail down which mobo I will be using.
CPU: QX6850, primarilly for the 1333 FSB, but might scale down to QX6700 if total end price is an issue, or possibly even drop to dual core with an E6700 if I need to cut back further.
Is it even worthwhile to go with 1333 FSB at this time?
If I do go with the QX6850, I was looking at the Asus Striker Extreme since it accepts both quad core/dual core, as well as supports FSB of 1333. Im a bit scared though, as from what I have read this mobo can be quite tempermental with POSTing as well as accepting different types of ram.
Are there any other FSB1333 mobos out there that are good overclockers?
Vid Card: EVGA 8800 GTX - got it in my current computer, and am very happy with it and will be
Memory: Still open, but was going to go with 2mb DDR2 800 to be able to take full advantage of the FSB of 1333 when its OCd. Am I incorrect in my information that since DDR2 is "dual pumped" I basically 2ble the speed of the DDR2 memory type and without OCing that is the max FSB that the memory will support?
Is it even worth going more than 2mb? I am told that Vista can utilize more than 2mb, but in XP pro more is likely not necessary no matter the application. Suggestions on brands/etc for the fasting/best OCer?
Cooling: Im thinking of going watercooled this time as my first attempt. Any suggestions on watercooled kits vs getting all the individual parts seperately? If I go air, I was thinking bout the Zalman 9700 since I have used that on a socket 775 before and it works well.
Hard Drive(s): Thinking bout another first here and doing a RAID since I am once again told performance is better. Looking at a pair of Seagate 15,000RPMs for most applications, OS, etc......, and possibly another HD not in RAID for general storage which would be a 7200RPM 300gbish or so I guess.
Sound/Case: open.....havnt really thought about it yet.
Thanks for your help!!!
Dawgdoc
Dawgdoc
