- Feb 19, 2005
- Southwest, USA
I recently had a static discharge on my HP brand ASUS M2N-LA mb. My fault. I upgraded the CPU several months ago from the stock Phenom X3 8400 (2.1 mHz) to the Phenom X3 8750BE (2.4 mHz) All was good, of course, until recently with the static discharge. The HP mb bios has no settings or options to speak of.
I bought from newegg the GIGABYTE GA-MA785GM-US2H AM3/AM2+/AM2 AMD 785G HDMI Micro ATX AMD Motherboard and a new OCZ 550W power supply. The insatallation went excellent and Windows 7 was very good with the change. I had to re-activate. but not did not have to re-install win7.
It has been a long time since I have seen a bios with so many options. I was thrilled. Once the operating system was happy I clocked the CPU at 15x (3.0 mHz) with one tick up on the cpu voltage. It booted and ran fine. I was impressed. My memory is DDR2 and does not like fsb increase at all.
I ran prime95 and it ran pretty hot. It crashed after a minute or two. I then started slowly. 13x (2.6) stock voltage and prime95 good. I worked my way up to 14x (2.8) with stock voltage (no increase) and it was very stable. Prime95 running Core temp 32c and other temps 61c, 56c, 49c. Not sure what those are connected with. Reported from speedfan. All on the stock HS/fan from HP with Artic silver 5.
I just wanted to share my experience and say it is nice to be back in the OC forum.
Cheers,
YB
Cheers,
YB
