rand0m_task
- Apr 14, 2020
I'm hoping to get some advice on painting my PC case. I have a Thermaltake Core x71 that I'd like to paint white. The case is made from SPCC and my initial plan was to:
1. Sand the case down to the bare metal
2. Apply self etching primer
3. Paint with Rustoleum white enamel
I'd like to avoid sanding it all down if possible, and just go with a Rust-Oleum paint that has the primer already mixed in. Anyway, any advice would be greatly appreciated.
Thanks,
Thanks,
