Thanks for all the help so far.
I finally finished my new loop since the upgrade to a X470 Taichi/ R7 2700 and Vega.
Here is a picture of the loop. My temps seem to be high. CPU is jumping around between high 40's and 60 at idle.
When I was bleeding the system I actually left the pump/res unmounted to I could hold it upright while I moved the case onto its side to help the bleed. I'm not seeing any air bubbles at this point.
Where would you start as far as finding the culprit?
