- Oct 12, 2001
- Folding in Barbados
There is a new MBM out
" Added: Intel ICH5 support, W83L785TS-S support, W83L785TR support, W83L785R support, W83627HF/ADM1027 Combo support as used on Tyan s2665UANF, ADM1030/ADM1025 Combo support as used on the Intel D850GB, AMD1030 dual support re-coded, Several Voltages added, thank you to all the users sending them in, $PCNAME will be replace with your PC's name in email subject line, Installer will by default enabled $2E and $4E scanning if you do a new install, but you can say no if you don't want to.
Changes: Higher compensation possible , Reset of the high/low list should now work better with 3rd party tools that push values into the sharedmemory (all values are set to current and the counter to 1 for "custom" sensors), You can now show up to 16 voltages, see the help file for more info.
Fixes: Typo in the ITE/SIS -12 voltage, Crash with GL520SM sensor chip, LM85 fan error, GL5xxxSM voltage wrong, In the misc directory is a batch file named "uninstall problems.bat" which should help out those users who have issues where unwise.exe does not find INSTALL.LOG (I sure hope this finally fixes it) "
Link : http://mbm.livewiredev.com/
