Hi!
I just got my new computer:
ASUS ROG Rampage V Edition 10, S-2011-3
Intel Core i7-6850K Prosessor
Corsair Dominator DDR4 3200MHz 16GB (2x8) x4
Intel® SSD 600p Series 256GB PCIe M.2
NZXT Kraken X61 CPU Cooler
And it is abit slow and some programs crashes, like Utorrent is slow and "not responding" from time to time, Battle.net app crashes some times and other stuff.
ive gotten BSOD a two times, but not in while now, with code IRQL_NOT_LESS_OR_EQUAL and SYSTEM_SERVICE_EXCEPTION... MEMTEST86 crashes at Test 2 at 16% after 15 sec's but this is proven to be a bios problem on every motherboards of this kind, And yes ive tryed MEMTEST86 both with the bios ver that the motherboard comes with and with the newest one. But ive only tryed Prime95 with the newest bios 1003. So when i use Prime95 it tells me:
[Fri Oct 21 23:40:45 2016]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Self-test 448K passed!
Self-test 8K passed!
[Fri Oct 21 23:45:52 2016]
Self-test 512K passed!
[Fri Oct 21 23:50:54 2016]
Self-test 12K passed!
FATAL ERROR: Rounding was 0.4997493725, expected less than 0.4
[Fri Oct 21 23:56:05 2016]
FATAL ERROR: Rounding was 0.4976275085, expected less than 0.4
Self-test 576K passed!
[Sat Oct 22 00:01:25 2016]
Self-test 16K passed!
Self-test 672K passed!
[Sat Oct 22 00:07:21 2016]
Self-test 20K passed!
[Sat Oct 22 00:13:26 2016]
Self-test 768K passed!
Self-test 24K passed!
[Sat Oct 22 00:18:56 2016]
FATAL ERROR: Rounding was 0.4980119206, expected less than 0.4
FATAL ERROR: Final result was 00000000, expected: 37F5DF1E.
When i first installed the watercooling system, i used a 115x socket bracket. I didnt think, but it fitted, but i had to punch holes in the screwhole thru a black plastic surface in order to screw the cooler on, wich on the MoBo's user manual shows if u use a stock fan on the cpu shows that its supposed to go thru the motherboard. Also the copper surface on the cpu cooler didnt connect properly to the cpu. I started the pc two times for 5 mins and then i noticed it and fixed it, installed the right screws (no barcket on 2011 sockets)
Can anyone explain to me what is happening here? When i used MEMTEST86 i tryed to take out the memory two by two in order to try and get the program to work but with no luck. Thats when i read that this is a bios problem they are currently trying to fix. Also i OC'ed the ram to 3200 mhz since it downgrades it to 2133 mhz originally.
