- May 4, 2011
So, I just installed my new PSU, an EVGA SUPERnova G3 650 watt PSU, and everything booted fine; Ran Aida64 since I also reapplied thermal paste and remounted the CPU heatsink.
11 minutes and 1 second in the pc locks up completely, the reset switch didn't function, had to shut off by holding power switch.
Went to boot back up, and it hung, Error code 55 on the debug module(I love that thing)(No memory installed as reported by ASROCK codes.) I figured, hey, that's possible, I did have to take out the ram closest to the heatsink to install the behemouth Heatsink. So I cracked open the case and pulled it out and pushed it back in.
Started back up no problem after that.
I'm thinking of running an extended stress test again to see if the issue replicates itself;
On a side note, is there any way to monitor the fan speeds of the PSU?
