Hi all, I recently built this computer. http://pcpartpicker.com/user/JM24/saved/2iO8 This was my first build so it is very possible I screwed something up. Honestly, the whole process has been kind of deflating, problem after problem.
Anyway, last night I finally booted it up. It booted fine to the BIOS with only a CPU fan error. Due to me forgetting things I had to open the case and turn it back on a couple of more times. I noticed that sometimes when I turned it on it would act like it was powering up, shut down again quickly (before the bios even had time) and restart itself. It would then be fine.
Tonight I installed Windows 8, installed drivers, etc and had to shut down to connect the side fan (forgot to plug it back in). When it booted back up it did it again (acted like it was powering on, shut down real fast, and powered back on again). This time because Windows was loaded, 8 said it didn't shut down correctly and had to check for problems. After it was done, Windows 8 rebooted the machine. Low and behold now it is stuck in a loop where it won't power on. Push the power button = power up, down, up, down, up, down. This all happens fairly quickly, the bios doesn't have time to load. Once in a while (I wasn't letting it do this too much for fear of damaging something) it would actually boot. Once booted it would reach the windows check again and fail on the reboot.
I am at a loss here. The only thing I can thing of is that one of the power connections isn't right, but I know the two major ones going into the mobo are in the right spot. Any ideas?
Also: The motherboard stays powered on the entire time during all of this rebooting.
Edit: May have fixed the issue but I could definitely use some feedback to verify.
On the motherboard there are places for reset ground, ground p+ led , etc etc
I used the little helper connector piece that came with the MOBO to connect those. I'm sure you all know what I am talking about, but it is the piece that lets you plug all those connectors into it first and then you plug that, as one solid, block into the motherboard. I noticed that the connectors didn't fit very snugly into that piece so I took them out of the piece and plugged them into the motherboard individually.
Anyone know if any of those could have been causing the problem? It was almost like the power button was being pushed over and over.
Edit: I just keep thinking that if it was a problem with the PSU then I would have had some issues with it while it was running. Once it boots up it is completely fine though. I just can't figure out what would cause it to keep rebooting like that (after a legitimate reboot) Again, after it booted it up it ran fine and only rebooted once it was told.
