I've had this rig for around three years now which I built from scratch. The specification is getting a bit dated so I have decided to overclock my e6320, stick 4GB more of 800MHz DDR2 in (to make 6GB) and stick a new GFX card in (most likely a ATi 4890).
I've read some useful guides around the site, this I found particularly useful so thanks for taking the time to write it 'graysky'.
I have been running several different programs to monitor my computers temperatures at standard speeds and it has went ok (in my opinion).
Here is my computer spec:
Mobo: GigaByte GA-P35C-DS3R
CPU: Intel Core2Duo e6320 (2X 1.86GHz)
CPU Cooling: Artic CoolingFreezer 7 Pro
RAM: GeiL 2GB 800MHz DDR2 RAM
GFX: Saphire Radeon x1950GT
PSU: 580W Tagan (cant remember exact name and box is in the attic)
Case: Phong II (Adjustable fan front & rear)
OS: Windows 7 Ultimate (64 bit)
Here is my computer idle:
And here is my computer whilst being tested by Prime95:
From what I've gathered my RAM is capable of of running without modification providing my CPU FSB doesn't surpass 800/2 = 400MHz?
If I was to run around 400MHz then that would equal a CPU speed of 400*7 = 2.8GHz. Thats a whole 1GHz faster then stock speed. So my RAM should suffice.
My RAM does however currently use a 2:3 FSBRAM ration, this will have to be changed, correct (see below picture)?
This is the part I am unsure of...
Besides that has anyone got any advice or input before I crack on?
E.g. "Hold on a second cowboy, your temperatures are too smoking to OC! Get them down first."
or.. "It's all looking good, carry on."
I'm right in pressuming I'd start by following the steps provided within this guide?
Big thanks to anyone who actually reads my whole post and replies with useful information,
Silverzx.
Silverzx.
