Hi am new to this forum and i thought i would post my little overclock and temperature to see what you guys think of it
my system spec
Motherboard=
Gigabyte GA-990XA-UD3 AMD 990X Socket AM3/AM3+ SATA 6Gb/s USB 3.0 DDR3 ATX Motherboard - GA-990XA-UD3
Ram=
Corsair Vengeance LP Blue 8GB (2x4GB) DDR3 PC3-12800 1600MHz Dual Channel Kit, Retail - CML8GX3M2A1600C9B
CPU=
AMD FX-8120 Black Editon 8 Core 3.1GHz Socket AM3+ Zambezi 125W CPU, Retail - FD8120FRGUBOX (oc to 4GHZ CPU vid @1.2125 20x200)
Cooling=
Modded H60 1 x 120 rad in a push/pull config & 1 x 240 rad
Have just rearranged my case cooling to try to get better temperature on my overclock with good outcome my thinks
now have 1x 240mm rad and fans in front of case,fans pulling air into case,1x 120mm fan infront of 2 HHDs pulling air over HHds to cool,front rad is connected to a moded H60,the rad on the H60 is setup as a pull/push,pulling the air from the inside of the case/the rad infront of the HHds is inline with the fan on the H60 rad,also have two 120mm fans at the top of the case to expelling air out the top of the case.
here is my idle temperature 10mins after starting my pc
By thetazs at 2012-04-24
And here is the temperature after running prime95 for over 30mins with no errors and no warnings
my system spec
Motherboard=
Ram=
CPU=
Cooling=
