Mystriss
- Jul 8, 2013
So I've got about six months to upgrade my current gaming rig before my next game comes out. Problem is, I've already hit the limits of what air cooling can handle with my custom rig. See, I'm a bit of a problem child, I insist on a small case, then proceed to stuff it with massively oversized components... Its a melt-down waiting to happen, and I know it, yet still continue on.
*cough* So water cooling because I no longer have a choice... I have only a basic gist of what I'm doing and honestly I'd pay someone to do this if there WAS anyone up here in Alaska I'd trust to do it. So I'm on my own here, lemme start with what I'm running atm and the problems, then you can all laugh at me for what I'm planning to upgrade to hmm?
Current Rig Pic So yea; Silverstone HTCP Case, Silverstone Strider 1200 PS, Sabertooth 990FX/Gen3 Rev2 MB, AMD Phenom II x6, HD6950 GPU, and 4 8gb low profile Ballistic dimms. I had a Coolermaster V6GT but I sent that to a friend who was worse off in the heat department than I was and picked up this Arctic 64pro rev2 whatever cpu cooler to use while I upgrade. No game atm so I'm running stock and heat is only a minor issue idle: Idle Temps Though there's no doubt my GPU gets danger zone hot: Ouch (I stopped the test cause 91c ain't healthy)
Anyway as you can see I'm already hitting the limits as it is, and then ... stoopid upgrades... I'm getting a FX-8350 easy enough yea? Uhm then well... I'd like to pick up a couple Devil 13 HD7990's *cough* Yes, in an HTPC case, I know, just humor me... I've got no space in the case obviously so I'm looking for an external radiator, and it needs to be able to handle the heat I'm going to be putting out cause those HD's run hot to begin with. I've been eyeballing the Koolance ERM-3K3UC Radiator which can supposedly handle the estimated 1000w from my GPU's and what 200w from my CPU, but I don't know the company at all. So a few questions:
The CPU block I was looking at is MIPS ICEFORCE HF I don't get much choice on the GPU block, EK seems to have the only one out there for the Devil.
Also, I was thinking to go with 3/8IDx1/2OD tubing, though I admit mostly cause it was in the middle of the two most common sizes - I need a bit of flexibility given the smaller case, so not too thick, but I need water flow too...
I'm not against running two separate radiator/pump systems (one for the GPUs and one for the CPU, or maybe a bigger one for one GPU and the CPU and a smaller for the second GPU, etc) but I'm not sure if that's a benefit or not.
I'm open to any options that would make this work, I love my HTPC case. I do know the GTX 690s and Titan's are sweet and perhaps a bit more suited to my case situation, but the second GPU is going to be 'later' in the upgrade process and I need the extra display ports on the Radeon's.
So that's the mess I'm in. Any help would be greatly appreciated.
I'm thinking to externally mount the rad under my desk, possible with this system? Can the pump handle it?
Is that 'kit' a good choice or is there a better one for a water cool noob like myself? OR am I better off building from scratch?
