Hello Overclockers I figured I'd post here in the thread to ask for some expertise regarding an issue I've been trying to trouble shoot on my first water cooling build for a while now. The issue I'm having is a constant small accumulation of micro bubbles in the CPU block that grow in size over a long period of time. I am currently running this spec of water cooling listed below.
Waterblock: XSPC RayStorm Neo
Water cooling Kit: EK-KIT L360 A Link here is provided for the Kit if needed https://www.ekwb.com/shop/ek-kit-l360-r2-0
Here is a diagram of the loop
This is the system
What I've done:
First time I've built this I had the similar issues so I constantly tilted it and got the large bubble out to the Rez, it would be fine for a couple of days then the micros bubble would appear over a couple of days and becoming a big bubble again. Eventually I did discover a micro leak from one of the Rad threads not being tightened enough so I fixed that.
I decided that must be the issue so I flushed the system, added new coolant, checked and re tightened some of the threads did a leak test and found no issues.
Fast forward, over a long period of time (Months 1-2) I've had no leaks but the micro bubbles still would accumulate in the same spot of the CPU block and grow into a big bubble overtime again. I thought maybe I still had some air trapped in the Rad. Every time it came back I tilted and pushed the bubbles out and refilled the Rez. After doing this 5 times it will be fine for a day or two then eventually micro bubbles would return and grow back. This is starting to give me a headache from constantly having to check it over and over.
Next Steps:
If this continues I am considering buying an entire new water cooling kit and salvage some of the parts and test them individually.
Before I do so I might consider getting a vacuum pump to see if there is a micro leak still persisting somewhere.
Do you guys have any advice for me to solve this issue?
This is the system
What I've done:
Next Steps:
