Hey all, Im new to the forums but I've been up for about 12 hours straight researching what to put into my new gaming rig and this seemed like an excellent place to ask for a little advice. I'm not entirely new to watercooling but I'm no pro by any means so bare with me.
My current setup is an aging (oh alright, ancient) Abit IC7-MAX3 mobo, Pentium 4 [email protected], GeForce 6800GT, 2x WD Raptor 74Gig HDD, and 2 Gigs of Kingston HyperX DDR400 memory all in a Koolance PC2-650 case. Watercooling only the CPU and GPU i've had reliable temps of about 26C-35C at idle and load, respectively.
If you have read the above and are tearing up, opening your wallets and are about to donate money to the "Schwag Relief Fund" then I can't blame you. The setup is about 5 years old and has been quite good to me thus far. Its time for an upgrade however and this time around I'd like to push the envelope of "budget" performance like this rig did half a century ago. As well, i would like to take a crack at building my own water cooling loop. I like to assemble my computers by hand and creating my own water cooling system seems like an interesting challenge. Plus, Koolance systems look like crap anymore, and are way too expensive.
So here's the setup in mind, sorry for the long back story. Any comments or advice would be much appreciated.
Hardware for the new computer is as follows:
Motherboard: ASUS Striker II Extreme
CPU: Intel Core2Duo E8500 @3.16GHz
Memory: Kinston HyperX DDR3 1600MHz
HDD: 2xWD Raptor 74Gig in Raid0
GPU: PNY GeForce 9800GTX+ (would like to upgrade to SLI in the future)
Water cooling hardware:
Case: Silverstone Temjin TJ-10 - I like the way this looks, and the ability to add a 102.2 radiator with only a $12 bracket seems very appealing. I dont like the look of a radiator bolted on to the back of a case.
Radiator: HWLabs Black Ice Stealth 240 - Going with this one due to the radiators position in the Temjin TJ-10. Thin, sleek design seems like it will be out of the way of the motherboard even with 2x120mm fans mounted to the bottom of it, yet still provide decent heat dissipation.
Reservoir: Swiftech MCRES-MICRO - Not too large, not too small. Mounting brackets = yay.
Pump: Swiftech MCP350 - Im not well versed in pumps, this one seems nice and small with a decent flow rate.
CPU Block: Danger Den MC-TDX - Heard good things about danger den, like the looks, construction looks solid.
GPU Block: Danger Den? - Not quite sure what i need here. On the 6800GT im simply cooling the GPU itself, cooler is not a full cover. New card is a 9800GTX+ and im not sure if I need full cover or not. Recommendations?
Chipset Block: Asus Striker II Extreme comes factory fitted with a Fusion waterblock that is connected to the northbridge and is said to cool the northbridge, southbridge, and mosfets. Good enough or go aftermarket?
I plan on running 3/8 tubing throughout the system and having the water from the radiator hit the CPU first then split into two lines to cool the GPU and Northbridge simultaneously before converging again into one line to run through the resevoir, then the pump, and back into the radiator.
There it all is, sorry about the giant wall of text. Any input you could provide would be excellent. I would like to know how this watercooling setup would stack up compared to other DIY setups or pre-made kits. How future proof do you think the setup would be? Will the heat dissipation meet my current needs? Will it meet my future needs (possible SLI config)? Thanks!!
