I heard that when burning in your cpu. the best way to do it is by lowering the fsb and muti as low as possible and up the vcore as much as possible while keeping an eye on temps for 24 hours, and then overclock and burn again??
Is this true? Want to verify?
Also I wanted to know about the L-3 bridge for AMD CPU's. If you enable it (mod it) then you get multipliers from like 5x-12.5x, right. IF you leave it unmodded the multipliers switch to like umm I think 13x-18x. This is the just of it, right? Would you recommend that I do this? Are the gains from doing the mod good?
Also umm I think that AMD 2100+ has a Vcore max of 1.85 or something like that. If you want to increase the voltage you need to mod it right. If so, is it worth it? I know that it can protentially increase stability. If it is worth it, is it difficult? Whats a link to the Vmod?
