- Apr 22, 2001
To start things off, I'm pretty peeved.
Approximately two years ago I purchased the MSi K7T Turbo KT133A motherboard along with a Duron 800mhz. After unlocking the chip 10+ times, I kept getting very strange results. It wasn't until a couple days later when somebody on this forum told me that the board had an issue with the bios and I had to flick the power supply switch off in the back after making changes to the multipliers. Not only that, but I was also not allowed to use the reset button because it actually cleared my cmos! #@^! lovely eh? So that was my first MSI experience, and it really ****ed me off. However, the board was stable so I didn't complain once all the bull was out of the way. MSi was still decent in my books due to the price.
7 Days ago I bought an MSI KT3 Ultra (NON-ARU) with an Athlon XP1600+ & 256MB PC2700 Samsung (all of the stuff is in my sig). As soon as I got it, I went to post the cpu and it didn't post, no beeps, nothing. Already I was worried but I reseated everything and tried again, still nothing. It wasn't until I reset the cmos that I got the initial post. Soon as I got into the bios, I checked the PC Health Status and was kinda dissapointed when there was a couple second delay between key presses and reaction (i originally thought my system locked). So in PC Health status, there was a couple second delay when I hit the up/down key. Great! But I didn't really care too much about that.
So everything worked fine, even though clearing the cmos was kind of unexpected. I then unlocked my XP and popped it in my system, all was fine. 9x196, working extremely well, not a problem. It was stable and awesome. A couple days later I rebooted the system and when it restarded it gave me an error about not being able to find an Operating System. Ok... I didn't change anything, I just rebooted. I went into the bios into the Standard Features, and there was no devices listed, nothing was detected. Again I got that feeling of "Oh ****, what now.. " and so I went to check the HD cable and it was plugged in properly at both ends, I then tried the secondary ide, and even tried a different cable with no luck. My last choice was to clear the cmos, fortunately it worked.
TODAY, I was benchmarking my ram speeds "someone in this section posted about sandra scores". I got a score of 2600MB/s, but remembered achieving 2700MB/s before. So I figured I'd go into the bios and tweak the ram timings. There really wasn't much to tweak though, my ram would only let me do CAS 2 2-5-3. I read up about the FAST mode setting in the manual and decided to give that a shot. ...... that would be the end of my overclocking fun with this board.
DEAD...
I saved the settings, I rebooted, I watched the monitor go off. I cleared the cmos (as I did several times during the cpu overclocking process). Pushed the power button, nothing, dead. And the feeling of "oh ****" is back.
I tried all sorts of things, removing all devices, trying to post, removing the battery, praying... Nothing helped. No post. I took the ram out and went to a buddies house to test it. It worked. Now I was pretty deep in **** because there were only 3 other options. Video card, Cpu, Motherboard.
Once I got home I put the ram back in and tried to boot, no post. Ok, so it's clearly not the ram. I didn't have a spare cpu to test, but a buddy came down with a PCI card to check if the AGP was dead. I tried the PCI, no luck. Ok, so it's not video, not ram. CPU or Motherboard.
After looking at the board and wondering where the diagnostic led's were, I remembered they came seperate. I hooked them up (The D-Led Bracket) and booted up.
Initial test (System Power ON) which states that the D-LED would hang if the CPU was damaged or not installed properly.
--*PASS*
Second test (Early Chipset Initialization)
--*PASS*
Third Test (Memory Detection test) states that the D-LED would hang if the memory was damaged.
--*PASS*
Fourth Test (skip?) Fifth test (skip?). I'm not entirely sure if the LED's go in order, but it appears that way. So it skipped the (decompressing BIOS Image to RAM) test, and the (Initializing Keyboard Controller) test. It immediately went to "TESTING VGA BIOS" at which point it hung. That was it, game-over. No matter what I tried, which video card, whether PCI OR AGP, it would hang at the VGA BIOS TEST.
I tested both the AGP & PCI video cards in my intel system, both worked.
So seeing as how it gets past the CPU test and skips the bios etc. I'm led to assume that the bios is FRIED.
The cpu had no reason to die, it wasn't getting hot, it had great cooling, it doesn't look damaged, doesn't smell.
Right now I'm baffled and quite peeved.
Fortunately I bought it from a friends shop so I shouldn't have any problems returning it and what not.
I need a beer
Last words... um... EPOX HERE I COME! Never again will I buy an MSi motherboard.
One last question (*just out of curiousity*), do any of you KT3 Ultra owners have that 'PC Health Status' lag, or the couple other things that occured?
If you read this entire rant, I admire you
DEAD...
--*PASS*
--*PASS*
--*PASS*
I need a beer
