After multiple months of fighting with my newest build's watercooling loop, I decided it was time to give up the fight, and go back to air cooling. So I took off my CPU and northbridge block, replaced the CPU with a fan (http://www.newegg.com/Product/Product.aspx?Item=N82E16835118075), and was getting ready to replace the northbridge block with the stock heatsink, when I realized, it was no longer in the motherboard's box. At this point I decided I'd keep a small watercooling loop, using sections of the loop that weren't giving me problems. So I put a bit of thermal grease on it, and put the waterblock right back on. So, I press the power button, and everything looks fine, until I realize my monitors aren't getting (or at least showing) any graphical information. I also notice that neither my keyboard or mouse have power.
I still don't really know a huge amount about diagnosing hardware problems, so I honestly have no idea what the problem is. The graphics card is getting power (fan spins up), the motherboard is obviously getting power (starts up just like normal, and has the green light on whenever the PSU is plugged in). So it doesn't seem to be a power issue. The only thing I can think of, if that the pump wasn't sucking the water for a bit, so there was a longer period without water than normal. That said, it wasn't longer than 10 seconds, and it was only twice, so in my relatively inexperienced opinion, I don't really think I damaged the northbridge.
Any thoughts?
Any thoughts?
