- Sep 4, 2003
- Ireland
Morning
I'm using the Noctua NH-L9a in the Lian Li PC-Q03. I'm not sure if you're familiar with the PC-Q03 but it relies on the PSU for extra cooling.
I'm wondering is it worth flipping the fan on the NH-L9a to draw heat away from the CPU and then into the PSU and out the back. Rather than pulling air towards the CPU.
I guess I could try this and check temps, but would like some feedback as to whether this is even worthwhile.
Idle the machine sits between 35-42c, probably 40c mostly. Playing minecraft it will sit around 60c or slightly more.
I'm using the thermal paste that came with the Noctua, should I maybe change it? Or should I be happy with those temps in such a small space?
Best regards
Best regards
