Hello! i have an 9900k sitting in a Gigabyte Aorus z390 Master mobo, cooled by a Noctua NH-D15.
Been messing around with adaptive voltage a bit with a goal of reducing temps and also finding the perfect offset to run on as low voltage as possible at a 4.7 all clock speed.
I am looking for opinions on whether or not should i consider my current settings stable and stop tweaking.
Below i added some of my observation from stress testing. I am not interested in overclocking any higher and i am not interested in messing with other settings such as llc as long as im stable. The 4.7 "stock" all core turbo frequency is enough for me, at least for now.
BIOS settings :
CPU clock ratio : 47
MCE : OFF
Turbo Boost : OFF
XMP : 1
Vcore mode : Normal
and a DVID offset.
-0.160 error 5m into p95(version 29.8) small fft (worker error & stop +a whea error)
-0.155 error 12m into p95(version 29.8) small fft (worker error & stop +a whea error)
-0.150 error 30m min into p95(version 29.8) small fft (worker error & stop +a whea error)
-0.140 error 1h 20m into p95(version 29.8) small fft (this time only the worker stop & error happened with no whea log in windows. Sign of getting closer to 100% stable?)
-0.130 passed 3hours 48minutes p95(version 29.8) small fft with no errors. Cpu package max was 86c after almost 4 hours of what is the absolutely worst case scenario, if i understand the prime version differences right? im assuming that running the 26.6 non AVX version after this is pointless as that could probably go on forever.
Vcore under the newest p95 small fft test load im running is between 1.116 - 1.128 with the latest -0.130 DVID offset.
I had no issues, errors, crashes or anything of that sort running games such as battlefield V and other stress tests such as Aida64, Realbench, Cinebench even at an offset of -0.150. It's just the P95 that kept producing errors up until i bumped it up to -0.130.
is this 100% stable? are my bios settings "healthy" for long term?
Thanks. Jan.
BIOS settings :
MCE : OFF
Turbo Boost : OFF
XMP : 1
Vcore mode : Normal
and a DVID offset.
Thanks. Jan.
