- May 10, 2004
- Brooklyn
that's weird...the HD problem, that is...
Aphex_Tom_9 said:that's weird...the HD problem, that is...
Senater_Cache said:well you didnt have to remove the barb from th eblock, actually Id have preffered that youy didnt as I am unsure how such actions affect your warranty with DD.
I would put some teflon tape into that thread with the new barb, just to be safe.
Also I wouldve chosen a less aggressive 90 angle. But nonetheless, what you have there seems to work out perfectly for you. Make sure you watch that replaced fitting on the DD6800 block realy close during leaktest.
Guderian said:If you don't want to change the vid to nb tubing, you could just pull that piece out and heat and stretch it till the tubing wall is thin enough to accomplish the turn. It might take a few tries though.
Well I heated pulled and burned my fingers so I gave up LMAOGuderian said:How thin did you get it.... you might be able to find someone with 6" of 1/8" or 1/16" walled tubing to hook you up. I wouldn't want to mess up the clean layout with angle joints any more than necessary: if I had any it'd be in the mail already.
