- Dec 1, 2007
- Near Toronto Canada
Duly noted, sir. No trusta da Rosewill. Damn those swindlers can make a pile of **** look pretty, though. Ah well. Advice appreciated and taken. Corsair it is!
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139036
This one should suit me, yes?
That case will be fine. For $50 you can get the 760T and get a wicked massive plexiglass window to view the guts of your new toy. Just sayin'....
Buy some brothers for the included fans (Hello, LED fans. I did not know you were a thing!)
There are colored LED light strips as well. Very good for systems with a side window. Useless for cases without one.
and the case is good to go (and also metal as ****)! So imposing, too! Exactly what I was getting at, with the color scheme and all that. Next issue! A series of worries have plagued me with some questions with the actual building process.
Will I need any specialized, specific tools?
Magnetized phillips head screwdriver. Anti static wrist strap or nitrile rubber gloves, non conductive surface (such as the bag the motherboard comes in). Do not build on carpet or with your shoes on.
What about static? I keep seeing horror stories of people accidentally zapping and destroying either a single part or many, and that would just devastate both my wallet and I. I'd seriously start bawling. Is this a legitimate concern?
Take an extra motherboard standoff (google it) and screw it into the power supply mounted in the case (do this first), attatch the anti static strap to this.
Is it safe to buy all these pieces over several weeks or months and assemble it a bit at a time, or should I just leave them in their boxes until I have them all and build it all at once?
No! Buy everything at once. Some new part at an amazing price may show up between when you start buying parts and when you finish. Save up, buy all at once. Always.
Is the build process pretty straightforward?
Carey Holzman. Watch his youtube videos. They're so detailed they're 2 hours long.
Windows 7's still alright, right? 8's newer and all, but I don't particularly care about which OS version I have as long as it successfully runs my ****, and 7 seems to work fine for other people. Also cheaper. Is there any reason I'd really want to get the new one?
Win 8 will support Direct X 12. Win 7 will not. Also, Win 7 will not be supported for as long as Win 8. You can make Win 8 run just like Win 7 with some 2 minute modifications. It's a lighter weight OS and is just all around better to have.
Motherboard standoff for reference:
