- Jan 31, 2002
Hey guys, it's been a while since I've posted... I've become gun shy and have been a bit busy.
Since some of my design methodology has been called into question I will not enter into a debate on certain areas of this topic, however I have some empirical information that is in direct contradiction to the graphs posted earlier.
In the early design of the Gemini block, I created a base that was approximately 2.5mm in thickness. I also created a block with the IDENTICAL water channel attributes, however the base was 1.25mm thick. In my testing, I only switched the blocks, nothing else was modified.
If I am to believe the model proposed here, my very very small flowrate (guessing, maybe 40-60gph) used in conjunction with the thick base should yield the best results... it absolutely did not. Infact the difference was 2 - 4C!!
My suspicion is that since we have a relatively small heat load (compared to the ability of copper and water to absorb the heat) that most of the thermal transfer takes place within a short distance of the core. Thus, the ideal block would probably be thin near the core and perhaps thicken by a 1mm or so as it extends outward.
One word of extreme caution. Most OCers out there are NOT mechanical. Copper is very very soft. If people use four springs with a combine compression force of 20+ lbs, you will begin to bend the bottom of the block if the block is thin! So keep in mind, when you design the block, that there are real machining and physical properties that should be considered.
I have a very slight design modification in mind to actually implement this theory and then test on a real system without any significant cost increase to the manufacturing process. Personally, I believe we are at the point of diminishing returns. 1C differences are purely bragging rights. =) The key factor which I believe MANY overlook is how much energy must be expended to obtain very good cooling.? The blocks designed for low flow allow the selection of a quieter, cooler running, more cost effective pump. Furthermore, the slower moving water can "sit" in a radiator or reservoir longer and perhaps enable better cooling of the water used in the system.
Ok fire away. =)
Ok fire away. =)
