SOLVED NVidia 670 repeated TDR timeouts since WDDM and Nvidia driver installed at same
mixin12s
West Bend/Milwaukee, WI
Okay, here's the problem. Got an NVidia 670 power edition a few months back, and recently a new monitor for 3d vision 2. Yesterday Windows 8 installed the notorious 304.48 WDDM driver on me in between updating my drivers. Due to not realizing this, upon reboot windows installed both drivers at the same time. Not going to explain everything I had to do to remove that driver and keep it from re-installing. I'll just say the symptoms from it led me to believe that was my only problem, or that that was the cause of the continuing problems I'm having now. After finally getting rid of that driver completely and trying to re-install the newest NVidia drivers (which were working before that), the driver installation kept failing in win8. Reformatted back to win7, got the driver installed... and have been experiencing tdr BSOD's ever since.. even when not at load just using web browser. Ran the windows experience index checker and it's showing 3d graphics at 6.5 with desktop graphics at 4.1. All this while my network adapter has also been fritzing out and dc'ing me, and I've realized this is happening at the same time... tdr timeout on gpu and wifi adapter hanging leading me to believe that it's something with the system. Being I have reformatted and gone back to windows 7 I really am at my wit's end and about to pull my hair out at this point. Post system info and dxdiag in a few, and try to find logfiles from crashes.
Tried: Uninstalling WDDM driver and re-installing NVidia driver, driver failed to install in win8 so reformatted to win7, TDR registry fix from microsoft=tdr's and wifi kick out less often but still anytime I try to do anything that puts stress on the system, turning intel speed stepping off (possible solution from nvidia), Uninstalling NVidia HD audio driver in case of possible conflict.. both no effect other than turning the speed stepping off seemed to raise my gaming graphics score in windows experience index from 4.1 at the time to 6.5.
Build: Intel 3570k w/ hyper 212, Nvidia 670 msi pe gpu, 2x4Gb Kingston 2400MHz RAM, OCZ vertex 3 and vertex 4 drives.. both 120Gb, Rosewill 630W PSU, Everything currently at stock settings. Before problems began ran cpu @ 4.6GHz and GPU at +100mv on gpu and 114% on power usage in afterburner but at stock speeds on everything... just to allow for higher NVidia boost.
********UPDATE********
I solved all of the problems I was experiencing now except one. Still getting repeated Driver Failed messages anytime the gpu has to re-initialize.. alt+tabbing to games, on bootup, switching from stereo 3d to 2d. Other than that all other problems are solved and PC is running like a champ again. Ran WEI and that gave my desktop and gaming graphics both 7.5 (with everything cpu and gpu-wise still at stock speeds)... Could the dual driver installation have possibly bricked my card?
Code:
EVENT LOG:
Log Name: System
Source: nvlddmkm
Date: 4/3/2013 6:43:56 AM
Event ID: 14
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Desktop-PC
Description:
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video7
00b2(1df4) 00000000 00000000
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="nvlddmkm" />
<EventID Qualifiers="49322">14</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2013-04-03T11:43:56.109865200Z" />
<EventRecordID>2545</EventRecordID>
<Channel>System</Channel>
<Computer>Desktop-PC</Computer>
<Security />
</System>
<EventData>
<Data>\Device\Video7</Data>
<Data>00b2(1df4) 00000000 00000000</Data>
<Binary>0000000002003000000000000E00AAC0000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Code:
SYSTEM INFO:
System Information report written at: 04/03/13 06:58:07
System Name: DESKTOP-PC
[System Summary]
Item Value
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-PC
System Manufacturer To Be Filled By O.E.M.
System Model To Be Filled By O.E.M.
System Type x64-based PC
Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz, 3400 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. P1.40, 1/16/2013
SMBIOS Version 2.7
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name Desktop-PC\Conscious
Time Zone Central Daylight Time
Installed Physical Memory (RAM) 8.00 GB
Total Physical Memory 7.89 GB
Available Physical Memory 6.24 GB
Total Virtual Memory 15.8 GB
Available Virtual Memory 13.8 GB
Page File Space 7.89 GB
Page File C:\pagefile.sys
[Hardware Resources]
[Conflicts/Sharing]
Resource Device
I/O Port 0x00000000-0x0000001F Direct memory access controller
I/O Port 0x00000000-0x0000001F PCI bus
I/O Port 0x000003C0-0x000003DF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
I/O Port 0x000003C0-0x000003DF NVIDIA GeForce GTX 670
I/O Port 0x00000065-0x0000006F Motherboard resources
I/O Port 0x00000070-0x00000077 System CMOS/real time clock
I/O Port 0x00000070-0x00000077 Motherboard resources
I/O Port 0x000004D0-0x000004D1 Programmable interrupt controller
I/O Port 0x000004D0-0x000004D1 Motherboard resources
I/O Port 0x0000E000-0x0000EFFF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
I/O Port 0x0000E000-0x0000EFFF NVIDIA GeForce GTX 670
Memory Address 0xFF000000-0xFFFFFFFF Intel(R) 82802 Firmware Hub Device
Memory Address 0xFF000000-0xFFFFFFFF Motherboard resources
Memory Address 0xF6000000-0xF70FFFFF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Memory Address 0xF6000000-0xF70FFFFF NVIDIA GeForce GTX 670
IRQ 16 Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
IRQ 16 Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
IRQ 16 NVIDIA GeForce GTX 670
IRQ 16 Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
IRQ 16 Intel(R) Management Engine Interface
IRQ 16 Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18
IRQ 17 High Definition Audio Controller
IRQ 17 Intel(R) 82801 PCI Bridge - 244E
IRQ 17 PCI standard PCI-to-PCI bridge
Memory Address 0xE0000000-0xE9FFFFFF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Memory Address 0xE0000000-0xE9FFFFFF NVIDIA GeForce GTX 670
Memory Address 0xA0000-0xBFFFF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Memory Address 0xA0000-0xBFFFF NVIDIA GeForce GTX 670
Memory Address 0xA0000-0xBFFFF PCI bus
I/O Port 0x000003B0-0x000003BB Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
I/O Port 0x000003B0-0x000003BB NVIDIA GeForce GTX 670
Memory Address 0xCFA00000-0xFEAFFFFF PCI bus
Memory Address 0xCFA00000-0xFEAFFFFF Motherboard resources
I/O Port 0x00000080-0x00000080 Motherboard resources
I/O Port 0x0000FFFF-0x0000FFFF Motherboard resources
Memory Address 0xEA100000-0xEA103FFF Realtek PCIe GBE Family Controller
Memory Address 0xEA100000-0xEA103FFF Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18
I/O Port 0x0000D000-0x0000D0FF Realtek PCIe GBE Family Controller
I/O Port 0x0000D000-0x0000D0FF Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18
[DMA]
Resource Device Status
Channel 4 Direct memory access controller OK
[Forced Hardware]
Device PNP Device ID
[I/O]
0x0000E000-0x0000EFFF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151 OK
0x0000E000-0x0000EFFF NVIDIA GeForce GTX 670 OK
0x000003B0-0x000003BB Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151 OK
0x000003B0-0x000003BB NVIDIA GeForce GTX 670 OK
0x000003C0-0x000003DF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151 OK
0x000003C0-0x000003DF NVIDIA GeForce GTX 670 OK
0x00000454-0x00000457 Motherboard resources OK
0x00000020-0x00000021 Programmable interrupt controller OK
0x00000024-0x00000025 Programmable interrupt controller OK
0x00000028-0x00000029 Programmable interrupt controller OK
0x0000002C-0x0000002D Programmable interrupt controller OK
0x00000030-0x00000031 Programmable interrupt controller OK
0x00000034-0x00000035 Programmable interrupt controller OK
0x00000038-0x00000039 Programmable interrupt controller OK
0x0000003C-0x0000003D Programmable interrupt controller OK
0x000000A0-0x000000A1 Programmable interrupt controller OK
0x000000A4-0x000000A5 Programmable interrupt controller OK
0x000000A8-0x000000A9 Programmable interrupt controller OK
0x000000AC-0x000000AD Programmable interrupt controller OK
0x000000B0-0x000000B1 Programmable interrupt controller OK
0x000000B4-0x000000B5 Programmable interrupt controller OK
0x000000B8-0x000000B9 Programmable interrupt controller OK
0x000000BC-0x000000BD Programmable interrupt controller OK
0x000004D0-0x000004D1 Programmable interrupt controller OK
0x000004D0-0x000004D1 Motherboard resources OK
0x00000040-0x00000043 System timer OK
0x00000050-0x00000053 System timer OK
0x0000F0B0-0x0000F0B7 Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller OK
0x0000F0A0-0x0000F0A3 Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller OK
0x0000F090-0x0000F097 Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller OK
0x0000F080-0x0000F083 Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller OK
0x0000F060-0x0000F07F Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller OK
0x00000000-0x0000001F Direct memory access controller OK
0x00000000-0x0000001F PCI bus OK
0x00000081-0x00000091 Direct memory access controller OK
0x00000093-0x0000009F Direct memory access controller OK
0x000000C0-0x000000DF Direct memory access controller OK
0x000003F8-0x000003FF Communications Port (COM1) OK
0x00000D00-0x0000FFFF PCI bus OK
0x00000070-0x00000077 System CMOS/real time clock OK
0x00000070-0x00000077 Motherboard resources OK
0x0000D000-0x0000D0FF Realtek PCIe GBE Family Controller OK
0x0000D000-0x0000D0FF Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18 OK
0x00000010-0x0000001F Motherboard resources OK
0x00000022-0x0000003F Motherboard resources OK
0x00000044-0x0000005F Motherboard resources OK
0x00000062-0x00000063 Motherboard resources OK
0x00000065-0x0000006F Motherboard resources OK
0x00000072-0x0000007F Motherboard resources OK
0x00000080-0x00000080 Motherboard resources OK
0x00000084-0x00000086 Motherboard resources OK
0x00000088-0x00000088 Motherboard resources OK
0x0000008C-0x0000008E Motherboard resources OK
0x00000090-0x0000009F Motherboard resources OK
0x000000A2-0x000000BF Motherboard resources OK
0x000000E0-0x000000EF Motherboard resources OK
0x00000290-0x0000029F Motherboard resources OK
0x0000002E-0x0000002F Motherboard resources OK
0x0000004E-0x0000004F Motherboard resources OK
0x00000061-0x00000061 Motherboard resources OK
0x00000063-0x00000063 Motherboard resources OK
0x00000067-0x00000067 Motherboard resources OK
0x00000092-0x00000092 Motherboard resources OK
0x000000B2-0x000000B3 Motherboard resources OK
0x00000680-0x0000069F Motherboard resources OK
0x00001000-0x0000100F Motherboard resources OK
0x0000FFFF-0x0000FFFF Motherboard resources OK
0x00000400-0x00000453 Motherboard resources OK
0x00000458-0x0000047F Motherboard resources OK
0x00000500-0x0000057F Motherboard resources OK
0x0000164E-0x0000164F Motherboard resources OK
0x000000F0-0x000000FF Numeric data processor OK
0x0000F040-0x0000F05F Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22 OK
[IRQs]
IRQ 16 Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151 OK
IRQ 16 Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D OK
IRQ 16 NVIDIA GeForce GTX 670 OK
IRQ 16 Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10 OK
IRQ 16 Intel(R) Management Engine Interface OK
IRQ 16 Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18 OK
IRQ 23 Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26 OK
IRQ 0 System timer OK
IRQ 17 High Definition Audio Controller OK
IRQ 17 Intel(R) 82801 PCI Bridge - 244E OK
IRQ 17 PCI standard PCI-to-PCI bridge OK
IRQ 19 Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller OK
IRQ 4294967293 Intel(R) USB 3.0 eXtensible Host Controller OK
IRQ 4 Communications Port (COM1) OK
IRQ 8 System CMOS/real time clock OK
IRQ 4294967294 Realtek PCIe GBE Family Controller OK
IRQ 13 Numeric data processor OK
IRQ 22 High Definition Audio Controller OK
IRQ 81 Microsoft ACPI-Compliant System OK
IRQ 82 Microsoft ACPI-Compliant System OK
IRQ 83 Microsoft ACPI-Compliant System OK
IRQ 84 Microsoft ACPI-Compliant System OK
IRQ 85 Microsoft ACPI-Compliant System OK
IRQ 86 Microsoft ACPI-Compliant System OK
IRQ 87 Microsoft ACPI-Compliant System OK
IRQ 88 Microsoft ACPI-Compliant System OK
IRQ 89 Microsoft ACPI-Compliant System OK
IRQ 90 Microsoft ACPI-Compliant System OK
IRQ 91 Microsoft ACPI-Compliant System OK
IRQ 92 Microsoft ACPI-Compliant System OK
IRQ 93 Microsoft ACPI-Compliant System OK
IRQ 94 Microsoft ACPI-Compliant System OK
IRQ 95 Microsoft ACPI-Compliant System OK
IRQ 96 Microsoft ACPI-Compliant System OK
IRQ 97 Microsoft ACPI-Compliant System OK
IRQ 98 Microsoft ACPI-Compliant System OK
IRQ 99 Microsoft ACPI-Compliant System OK
IRQ 100 Microsoft ACPI-Compliant System OK
IRQ 101 Microsoft ACPI-Compliant System OK
IRQ 102 Microsoft ACPI-Compliant System OK
IRQ 103 Microsoft ACPI-Compliant System OK
IRQ 104 Microsoft ACPI-Compliant System OK
IRQ 105 Microsoft ACPI-Compliant System OK
IRQ 106 Microsoft ACPI-Compliant System OK
IRQ 107 Microsoft ACPI-Compliant System OK
IRQ 108 Microsoft ACPI-Compliant System OK
IRQ 109 Microsoft ACPI-Compliant System OK
IRQ 110 Microsoft ACPI-Compliant System OK
IRQ 111 Microsoft ACPI-Compliant System OK
IRQ 112 Microsoft ACPI-Compliant System OK
IRQ 113 Microsoft ACPI-Compliant System OK
IRQ 114 Microsoft ACPI-Compliant System OK
IRQ 115 Microsoft ACPI-Compliant System OK
IRQ 116 Microsoft ACPI-Compliant System OK
IRQ 117 Microsoft ACPI-Compliant System OK
IRQ 118 Microsoft ACPI-Compliant System OK
IRQ 119 Microsoft ACPI-Compliant System OK
IRQ 120 Microsoft ACPI-Compliant System OK
IRQ 121 Microsoft ACPI-Compliant System OK
IRQ 122 Microsoft ACPI-Compliant System OK
IRQ 123 Microsoft ACPI-Compliant System OK
IRQ 124 Microsoft ACPI-Compliant System OK
IRQ 125 Microsoft ACPI-Compliant System OK
IRQ 126 Microsoft ACPI-Compliant System OK
IRQ 127 Microsoft ACPI-Compliant System OK
IRQ 128 Microsoft ACPI-Compliant System OK
IRQ 129 Microsoft ACPI-Compliant System OK
IRQ 130 Microsoft ACPI-Compliant System OK
IRQ 131 Microsoft ACPI-Compliant System OK
IRQ 132 Microsoft ACPI-Compliant System OK
IRQ 133 Microsoft ACPI-Compliant System OK
IRQ 134 Microsoft ACPI-Compliant System OK
IRQ 135 Microsoft ACPI-Compliant System OK
IRQ 136 Microsoft ACPI-Compliant System OK
IRQ 137 Microsoft ACPI-Compliant System OK
IRQ 138 Microsoft ACPI-Compliant System OK
IRQ 139 Microsoft ACPI-Compliant System OK
IRQ 140 Microsoft ACPI-Compliant System OK
IRQ 141 Microsoft ACPI-Compliant System OK
IRQ 142 Microsoft ACPI-Compliant System OK
IRQ 143 Microsoft ACPI-Compliant System OK
IRQ 144 Microsoft ACPI-Compliant System OK
IRQ 145 Microsoft ACPI-Compliant System OK
IRQ 146 Microsoft ACPI-Compliant System OK
IRQ 147 Microsoft ACPI-Compliant System OK
IRQ 148 Microsoft ACPI-Compliant System OK
IRQ 149 Microsoft ACPI-Compliant System OK
IRQ 150 Microsoft ACPI-Compliant System OK
IRQ 151 Microsoft ACPI-Compliant System OK
IRQ 152 Microsoft ACPI-Compliant System OK
IRQ 153 Microsoft ACPI-Compliant System OK
IRQ 154 Microsoft ACPI-Compliant System OK
IRQ 155 Microsoft ACPI-Compliant System OK
IRQ 156 Microsoft ACPI-Compliant System OK
IRQ 157 Microsoft ACPI-Compliant System OK
IRQ 158 Microsoft ACPI-Compliant System OK
IRQ 159 Microsoft ACPI-Compliant System OK
IRQ 160 Microsoft ACPI-Compliant System OK
IRQ 161 Microsoft ACPI-Compliant System OK
IRQ 162 Microsoft ACPI-Compliant System OK
IRQ 163 Microsoft ACPI-Compliant System OK
IRQ 164 Microsoft ACPI-Compliant System OK
IRQ 165 Microsoft ACPI-Compliant System OK
IRQ 166 Microsoft ACPI-Compliant System OK
IRQ 167 Microsoft ACPI-Compliant System OK
IRQ 168 Microsoft ACPI-Compliant System OK
IRQ 169 Microsoft ACPI-Compliant System OK
IRQ 170 Microsoft ACPI-Compliant System OK
IRQ 171 Microsoft ACPI-Compliant System OK
IRQ 172 Microsoft ACPI-Compliant System OK
IRQ 173 Microsoft ACPI-Compliant System OK
IRQ 174 Microsoft ACPI-Compliant System OK
IRQ 175 Microsoft ACPI-Compliant System OK
IRQ 176 Microsoft ACPI-Compliant System OK
IRQ 177 Microsoft ACPI-Compliant System OK
IRQ 178 Microsoft ACPI-Compliant System OK
IRQ 179 Microsoft ACPI-Compliant System OK
IRQ 180 Microsoft ACPI-Compliant System OK
IRQ 181 Microsoft ACPI-Compliant System OK
IRQ 182 Microsoft ACPI-Compliant System OK
IRQ 183 Microsoft ACPI-Compliant System OK
IRQ 184 Microsoft ACPI-Compliant System OK
IRQ 185 Microsoft ACPI-Compliant System OK
IRQ 186 Microsoft ACPI-Compliant System OK
IRQ 187 Microsoft ACPI-Compliant System OK
IRQ 188 Microsoft ACPI-Compliant System OK
IRQ 189 Microsoft ACPI-Compliant System OK
IRQ 190 Microsoft ACPI-Compliant System OK
IRQ 10 Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22 OK
[Memory]
0xF6000000-0xF70FFFFF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151 OK
0xF6000000-0xF70FFFFF NVIDIA GeForce GTX 670 OK
0xE0000000-0xE9FFFFFF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151 OK
0xE0000000-0xE9FFFFFF NVIDIA GeForce GTX 670 OK
0xA0000-0xBFFFF Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151 OK
0xA0000-0xBFFFF NVIDIA GeForce GTX 670 OK
0xA0000-0xBFFFF PCI bus OK
0xF7817000-0xF78173FF Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26 OK
0xFF000000-0xFFFFFFFF Intel(R) 82802 Firmware Hub Device OK
0xFF000000-0xFFFFFFFF Motherboard resources OK
0xF7818000-0xF78183FF Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D OK
0xF7080000-0xF7083FFF High Definition Audio Controller OK
0xF7816000-0xF78167FF Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller OK
0xF7800000-0xF780FFFF Intel(R) USB 3.0 eXtensible Host Controller OK
0xFED00000-0xFED003FF High precision event timer OK
0xE8000000-0xE9FFFFFF NVIDIA GeForce GTX 670 OK
0xF781A000-0xF781A00F Intel(R) Management Engine Interface OK
0xD0000-0xD3FFF PCI bus OK
0xD4000-0xD7FFF PCI bus OK
0xD8000-0xDBFFF PCI bus OK
0xDC000-0xDFFFF PCI bus OK
0xE0000-0xE3FFF PCI bus OK
0xE4000-0xE7FFF PCI bus OK
0xCFA00000-0xFEAFFFFF PCI bus OK
0xCFA00000-0xFEAFFFFF Motherboard resources OK
0xFED40000-0xFED44FFF System board OK
0xEA104000-0xEA104FFF Realtek PCIe GBE Family Controller OK
0xEA100000-0xEA103FFF Realtek PCIe GBE Family Controller OK
0xEA100000-0xEA103FFF Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18 OK
0x20000000-0x201FFFFF System board OK
0x40004000-0x40004FFF System board OK
0xFED1C000-0xFED1FFFF Motherboard resources OK
0xFED10000-0xFED17FFF Motherboard resources OK
0xFED18000-0xFED18FFF Motherboard resources OK
0xFED19000-0xFED19FFF Motherboard resources OK
0xF8000000-0xFBFFFFFF Motherboard resources OK
0xFED20000-0xFED3FFFF Motherboard resources OK
0xFED90000-0xFED93FFF Motherboard resources OK
0xFED45000-0xFED8FFFF Motherboard resources OK
0xFEE00000-0xFEEFFFFF Motherboard resources OK
0xF7810000-0xF7813FFF High Definition Audio Controller OK
0xF7815000-0xF78150FF Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22 OK
[Components]
[Multimedia]
[Audio Codecs]
CODEC Manufacturer Description Status File Version Size Creation Date
c:\windows\system32\msg711.acm Microsoft Corporation OK C:\Windows\system32\MSG711.ACM 6.1.7600.16385 14.50 KB (14,848 bytes) 7/13/2009 7:18 PM
c:\windows\system32\imaadp32.acm Microsoft Corporation OK C:\Windows\system32\IMAADP32.ACM 6.1.7600.16385 21.50 KB (22,016 bytes) 7/13/2009 7:18 PM
c:\windows\system32\msgsm32.acm Microsoft Corporation OK C:\Windows\system32\MSGSM32.ACM 6.1.7600.16385 28.50 KB (29,184 bytes) 7/13/2009 7:18 PM
c:\windows\system32\msadp32.acm Microsoft Corporation OK C:\Windows\system32\MSADP32.ACM 6.1.7600.16385 23.50 KB (24,064 bytes) 7/13/2009 7:18 PM
c:\windows\system32\l3codeca.acm Fraunhofer Institut Integrierte Schaltungen IIS Fraunhofer IIS MPEG Layer-3 Codec OK C:\Windows\system32\L3CODECA.ACM 1.9.0.401 79.50 KB (81,408 bytes) 7/13/2009 7:22 PM
[Video Codecs]
c:\windows\system32\msrle32.dll Microsoft Corporation OK C:\Windows\system32\MSRLE32.DLL 6.1.7601.17514 16.00 KB (16,384 bytes) 11/20/2010 9:24 PM
c:\windows\system32\msvidc32.dll Microsoft Corporation OK C:\Windows\system32\MSVIDC32.DLL 6.1.7601.17514 38.00 KB (38,912 bytes) 11/20/2010 9:24 PM
c:\windows\system32\msyuv.dll Microsoft Corporation OK C:\Windows\system32\MSYUV.DLL 6.1.7601.17514 25.00 KB (25,600 bytes) 11/20/2010 9:24 PM
c:\windows\system32\iyuv_32.dll Microsoft Corporation OK C:\Windows\system32\IYUV_32.DLL 6.1.7601.17514 53.00 KB (54,272 bytes) 11/20/2010 9:24 PM
c:\windows\system32\tsbyuv.dll Microsoft Corporation OK C:\Windows\system32\TSBYUV.DLL 6.1.7601.17514 14.50 KB (14,848 bytes) 11/20/2010 9:24 PM
[CD-ROM]
Item Value
Drive E:
Description CD-ROM Drive
Media Loaded Yes
Media Type DVD Writer
Name TSSTcorp CDDVDW SH-224BB
Manufacturer (Standard CD-ROM drives)
Status OK
Transfer Rate 1025.13 kbytes/sec
SCSI Target ID 2
PNP Device ID IDE\CDROMTSSTCORP_CDDVDW_SH-224BB________________SB00____\4&1A58A66F&0&0.2.0
Driver c:\windows\system32\drivers\cdrom.sys (6.1.7601.17514, 144.00 KB (147,456 bytes), 11/20/2010 9:23 PM)
[Sound Device]
Item Value
Name NVIDIA High Definition Audio
Manufacturer NVIDIA
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_10DE&DEV_0040&SUBSYS_14622842&REV_1001\5&3630A55C&0&0001
Driver c:\windows\system32\drivers\nvhda64v.sys (1.3.23.1, 189.93 KB (194,488 bytes), 4/3/2013 6:37 AM)
Name Realtek High Definition Audio
Manufacturer Realtek
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_18498892&REV_1003\4&1EABB83B&0&0001
Driver c:\windows\system32\drivers\rtkvhd64.sys (6.0.1.6690, 3.91 MB (4,097,808 bytes), 4/3/2013 6:10 AM)
Name Intel(R) Display Audio
Manufacturer Intel(R) Corporation
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_8086&DEV_2806&SUBSYS_80860101&REV_1000\4&1EABB83B&0&0301
Driver c:\windows\system32\drivers\intcdaud.sys (6.14.0.3090, 323.50 KB (331,264 bytes), 4/3/2013 6:12 AM)
[Display]
Item Value
Name Intel(R) HD Graphics 4000
PNP Device ID PCI\VEN_8086&DEV_0162&SUBSYS_01621849&REV_09\3&11583659&0&10
Adapter Type Not Available, Intel Corporation compatible
Adapter Description Intel(R) HD Graphics 4000
Adapter RAM Not Available
Installed Drivers igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver Version 8.15.10.2761
INF File oem15.inf (iIVBD0 section)
Color Planes Not Available
Color Table Entries 4294967296
Resolution 1920 x 1080 x 60 hertz
Bits/Pixel 32
Driver c:\windows\system32\drivers\igdkmd64.sys (8.15.10.2761, 14.08 MB (14,759,520 bytes), 4/3/2013 6:12 AM)
Name NVIDIA GeForce GTX 670
PNP Device ID PCI\VEN_10DE&DEV_1189&SUBSYS_28421462&REV_A1\4&15001D53&0&0008
Adapter Type GeForce GTX 670, NVIDIA compatible
Adapter Description NVIDIA GeForce GTX 670
Adapter RAM 2.00 GB (2,147,155,968 bytes)
Installed Drivers nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver Version 9.18.13.1407
INF File oem19.inf (Section062 section)
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xE8000000-0xE9FFFFFF
IRQ Channel IRQ 16
Driver c:\windows\system32\drivers\nvlddmkm.sys (9.18.13.1407, 10.53 MB (11,040,544 bytes), 4/3/2013 6:37 AM)
[Infrared]
Item Value
[Input]
[Keyboard]
Item Value
Description USB Input Device
Name Enhanced (101- or 102-key)
Layout 00000409
PNP Device ID USB\VID_1532&PID_0109&MI_00\7&726153&0&0000
Number of Function Keys 12
Driver c:\windows\system32\drivers\hidusb.sys (6.1.7601.17514, 29.50 KB (30,208 bytes), 11/20/2010 9:23 PM)
Layout 00000409
PNP Device ID USB\VID_1532&PID_0015&MI_01\6&118456D2&0&0001
[Pointing Device]
Item Value
Hardware Type USB Input Device
Number of Buttons 0
Status OK
PNP Device ID USB\VID_1532&PID_0015&MI_00\6&118456D2&0&0000
Power Management Supported No
Double Click Threshold Not Available
Handedness Not Available
[Modem]
Item Value
[Network]
[Adapter]
Item Value
Name [00000000] WAN Miniport (SSTP)
Product Type WAN Miniport (SSTP)
Installed Yes
PNP Device ID ROOT\MS_SSTPMINIPORT\0000
Last Reset 4/3/2013 6:38 AM
Index 0
Service Name RasSstp
IP Address Not Available
IP Subnet Not Available
Default IP Gateway Not Available
DHCP Enabled No
DHCP Server Not Available
DHCP Lease Expires Not Available
DHCP Lease Obtained Not Available
MAC Address Not Available
Driver c:\windows\system32\drivers\rassstp.sys (6.1.7600.16385, 82.00 KB (83,968 bytes), 7/13/2009 7:10 PM)
Name [00000001] WAN Miniport (IKEv2)
Product Type WAN Miniport (IKEv2)
Installed Yes
PNP Device ID ROOT\MS_AGILEVPNMINIPORT\0000
Index 1
Service Name RasAgileVpn
DHCP Enabled No
Driver c:\windows\system32\drivers\agilevpn.sys (6.1.7600.16385, 59.00 KB (60,416 bytes), 7/13/2009 7:10 PM)
Name [00000002] WAN Miniport (L2TP)
Product Type WAN Miniport (L2TP)
Installed Yes
PNP Device ID ROOT\MS_L2TPMINIPORT\0000
Index 2
Service Name Rasl2tp
DHCP Enabled No
Driver c:\windows\system32\drivers\rasl2tp.sys (6.1.7601.17514, 126.50 KB (129,536 bytes), 11/20/2010 9:24 PM)
Name [00000003] WAN Miniport (PPTP)
Product Type WAN Miniport (PPTP)
Installed Yes
PNP Device ID ROOT\MS_PPTPMINIPORT\0000
Index 3
Service Name PptpMiniport
DHCP Enabled No
Driver c:\windows\system32\drivers\raspptp.sys (6.1.7601.17514, 108.50 KB (111,104 bytes), 11/20/2010 9:24 PM)
Name [00000004] WAN Miniport (PPPOE)
Product Type WAN Miniport (PPPOE)
Installed Yes
PNP Device ID ROOT\MS_PPPOEMINIPORT\0000
Index 4
Service Name RasPppoe
DHCP Enabled No
Driver c:\windows\system32\drivers\raspppoe.sys (6.1.7600.16385, 90.50 KB (92,672 bytes), 7/13/2009 7:10 PM)
Name [00000005] WAN Miniport (IPv6)
Product Type WAN Miniport (IPv6)
Installed Yes
PNP Device ID ROOT\MS_NDISWANIPV6\0000
Index 5
Service Name NdisWan
DHCP Enabled No
Driver c:\windows\system32\drivers\ndiswan.sys (6.1.7601.17514, 160.50 KB (164,352 bytes), 11/20/2010 9:24 PM)
Name [00000006] WAN Miniport (Network Monitor)
Product Type WAN Miniport (Network Monitor)
Installed Yes
PNP Device ID ROOT\MS_NDISWANBH\0000
Index 6
DHCP Enabled No
Name [00000007] Realtek PCIe GBE Family Controller
Adapter Type Ethernet 802.3
Product Type Realtek PCIe GBE Family Controller
Installed Yes
PNP Device ID PCI\VEN_10EC&DEV_8168&SUBSYS_81681849&REV_06\4&2B8260C3&0&00E4
Index 7
Service Name RTL8167
DHCP Enabled Yes
MAC Address BC:5F:F4:66:03:96
Memory Address 0xEA104000-0xEA104FFF
IRQ Channel IRQ 4294967294
Driver c:\windows\system32\drivers\rt64win7.sys (7.65.1025.2012, 751.14 KB (769,168 bytes), 2/15/2013 7:26 PM)
Name [00000008] WAN Miniport (IP)
Product Type WAN Miniport (IP)
Installed Yes
PNP Device ID ROOT\MS_NDISWANIP\0000
Index 8
DHCP Enabled No
Name [00000009] Microsoft ISATAP Adapter
Adapter Type Tunnel
Product Type Microsoft ISATAP Adapter
Installed Yes
PNP Device ID ROOT\*ISATAP\0000
Index 9
Service Name tunnel
DHCP Enabled No
Driver c:\windows\system32\drivers\tunnel.sys (6.1.7601.17514, 122.50 KB (125,440 bytes), 11/20/2010 9:24 PM)
Name [00000010] RAS Async Adapter
Product Type RAS Async Adapter
Installed Yes
PNP Device ID Not Available
Index 10
Service Name AsyncMac
DHCP Enabled No
Name [00000011] Microsoft Teredo Tunneling Adapter
Adapter Type Tunnel
Product Type Microsoft Teredo Tunneling Adapter
Installed Yes
PNP Device ID ROOT\*TEREDO\0000
Index 11
Service Name tunnel
DHCP Enabled No
Name [00000012] NETGEAR WNDA3100v2 N600 Wireless Dual Band USB Adapter
Product Type NETGEAR WNDA3100v2 N600 Wireless Dual Band USB Adapter
Installed Yes
PNP Device ID USB\VID_0846&PID_9011\0
Index 12
Service Name BCMH43XX
IP Address 192.168.1.109, fe80::418b:55f5:D 618:2b41, 2602:30a:c0ba:4c30:e9c2:3086:bcff:470b, 2602:30a:c0ba:4c30:418b:55f5:D 618:2b41
IP Subnet 255.255.255.0, 64, 128, 64
Default IP Gateway 192.168.1.254, fe80::D e45:17ff:feb5:6e70
DHCP Enabled Yes
DHCP Server 192.168.1.254
DHCP Lease Expires 4/4/2013 6:47 AM
DHCP Lease Obtained 4/3/2013 6:47 AM
MAC Address 00:8E:F2:89:BF:6D
Driver c:\windows\system32\drivers\bcmwlhigh664.sys (5.100.68.48, 1.20 MB (1,256,192 bytes), 4/3/2013 6:21 AM)
Name [00000013] Microsoft ISATAP Adapter
Adapter Type Tunnel
Installed Yes
PNP Device ID ROOT\*ISATAP\0001
Index 13
Service Name tunnel
DHCP Enabled No
[Protocol]
Item Value
Name MSAFD Tcpip [TCP/IP]
Connectionless Service No
Guarantees Delivery Yes
Guarantees Sequencing Yes
Maximum Address Size 16 bytes
Maximum Message Size 0 bytes
Message Oriented No
Minimum Address Size 16 bytes
Pseudo Stream Oriented No
Supports Broadcasting No
Supports Connect Data No
Supports Disconnect Data No
Supports Encryption No
Supports Expedited Data Yes
Supports Graceful Closing Yes
Supports Guaranteed Bandwidth No
Supports Multicasting No
Name MSAFD Tcpip [UDP/IP]
Connectionless Service Yes
Guarantees Delivery No
Guarantees Sequencing No
Maximum Message Size 63.99 KB (65,527 bytes)
Message Oriented Yes
Supports Broadcasting Yes
Supports Expedited Data No
Supports Graceful Closing No
Supports Multicasting Yes
Name MSAFD Tcpip [TCP/IPv6]
Maximum Address Size 28 bytes
Message Oriented No
Minimum Address Size 28 bytes
Name MSAFD Tcpip [UDP/IPv6]
Name RSVP TCPv6 Service Provider
Message Oriented No
Supports Encryption Yes
Name RSVP TCP Service Provider
Message Oriented No
Name RSVP UDPv6 Service Provider
Name RSVP UDP Service Provider
[WinSock]
Item Value
File c:\windows\syswow64\wsock32.dll
Size 15.00 KB (15,360 bytes)
Version 6.1.7600.16385
File c:\windows\system32\wsock32.dll
Size 18.00 KB (18,432 bytes)
[Ports]
[Serial]
Item Value
Name Communications Port (COM1)
Status OK
PNP Device ID ACPI\PNP0501\1
Maximum Input Buffer Size 0
Maximum Output Buffer Size No
Settable Baud Rate Yes
Settable Data Bits Yes
Settable Flow Control Yes
Settable Parity Yes
Settable Parity Check Yes
Settable Stop Bits Yes
Settable RLSD Yes
Supports RLSD Yes
Supports 16 Bit Mode No
Supports Special Characters No
Baud Rate 9600
Bits/Byte 8
Stop Bits 1
Parity None
Busy No
Abort Read/Write on Error No
Binary Mode Enabled Yes
Continue XMit on XOff No
CTS Outflow Control No
Discard NULL Bytes No
DSR Outflow Control 0
DSR Sensitivity 0
DTR Flow Control Type Enable
EOF Character 0
Error Replace Character 0
Error Replacement Enabled No
Event Character 0
Parity Check Enabled No
RTS Flow Control Type Enable
XOff Character 19
XOffXMit Threshold 512
XOn Character 17
XOnXMit Threshold 2048
XOnXOff InFlow Control 0
XOnXOff OutFlow Control 0
I/O Port 0x000003F8-0x000003FF
IRQ Channel IRQ 4
Driver c:\windows\system32\drivers\serial.sys (6.1.7600.16385, 92.00 KB (94,208 bytes), 7/13/2009 7:00 PM)
[Parallel]
Item Value
[Storage]
[Drives]
Item Value
Drive C:
Description Local Fixed Disk
Compressed No
File System NTFS
Size 119.14 GB (127,928,365,056 bytes)
Free Space 36.23 GB (38,903,103,488 bytes)
Volume Name
Volume Serial Number D6A8187C
Drive D:
Compressed No
File System NTFS
Size 111.79 GB (120,031,539,200 bytes)
Free Space 104.19 GB (111,875,190,784 bytes)
Volume Name New Volume
Volume Serial Number DC7C3B77
Drive E:
Description CD-ROM Disc
[Disks]
Item Value
Description Disk drive
Manufacturer (Standard disk drives)
Model OCZ-VERTEX3
Bytes/Sector 512
Media Loaded Yes
Media Type Fixed hard disk
Partitions 1
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 0
SCSI Target ID 1
Sectors/Track 63
Size 111.79 GB (120,031,511,040 bytes)
Total Cylinders 14,593
Total Sectors 234,436,545
Total Tracks 3,721,215
Tracks/Cylinder 255
Partition Disk #1, Partition #0
Partition Size 111.79 GB (120,031,543,296 bytes)
Partition Starting Offset 1,048,576 bytes
Model OCZ-VERTEX4
Bytes/Sector 512
Media Loaded Yes
Partitions 2
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 0
SCSI Target ID 0
Sectors/Track 63
Size 119.24 GB (128,034,708,480 bytes)
Total Cylinders 15,566
Total Sectors 250,067,790
Total Tracks 3,969,330
Tracks/Cylinder 255
Partition Disk #0, Partition #0
Partition Size 100.00 MB (104,857,600 bytes)
Partition Disk #0, Partition #1
Partition Size 119.14 GB (127,928,369,152 bytes)
Partition Starting Offset 105,906,176 bytes
[SCSI]
Item Value
[IDE]
Item Value
Name Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller
Manufacturer Intel
Status OK
PNP Device ID PCI\VEN_8086&DEV_1E02&SUBSYS_1E021849&REV_04\3&11583659&0&FA
I/O Port 0x0000F0B0-0x0000F0B7
I/O Port 0x0000F0A0-0x0000F0A3
I/O Port 0x0000F090-0x0000F097
I/O Port 0x0000F080-0x0000F083
I/O Port 0x0000F060-0x0000F07F
Memory Address 0xF7816000-0xF78167FF
IRQ Channel IRQ 19
Driver c:\windows\system32\drivers\iastor.sys (11.2.0.1006, 555.81 KB (569,152 bytes), 4/3/2013 6:09 AM)
[Printing]
Name Driver Port Name Server Name
Microsoft XPS Document Writer Microsoft XPS Document Writer XPSPort: Not Available
Fax Microsoft Shared Fax Driver SHRFAX: Not Available
[Problem Devices]
Device PNP Device ID Error Code
Intel(R) HD Graphics 4000 PCI\VEN_8086&DEV_0162&SUBSYS_01621849&REV_09\3&11583659&0&10 This device is disabled.
Well apparently the issue wasn't the WDDM drivers, or the GPU at all. After 3 days of analysis, and my bios showing my memory timings as being set correctly I moused over one of my sticks on the motherboard in my bios, and it came up as being set with 1333MHz timings... being a fritzed memory controller is an easy fix I reseated my RAM, set it to the proper 2400MHz timings and VOILA! problem solved. After 3 days of >4 hours sleep time for bed.
