NZXT S340 Red/Black & H440 Red/Black
psyshack
Okmulgee, Ok.
I have been waiting for 6 weeks or better for my newly released S340RB. I had it on preorder with NewEgg as soon as they posted it for preorder. So this should be one of the first in the wild. I like the case and am very glad I got it. It's smaller than a H440. But still easy to work with. And it has the right amount of red. The H440 had far to much red cheap plastic. H440 really was tacky, cheap and tawdry looking out of the box. Not so with the S340RB. Just the right amount of red. And a great little sister for her big brother H440. Just what I was looking for.
S340RB as it is today:
4790K Delided ( running with lid right now frown emoticon ) @ 4.8ghz
Tim: Liquid Ultra between slug & lid, GC Extreme between lid & cold plate.
GA-Z97X-SLI ( the bios sucks )
16gb GSkills Trident X 2133
2X EVGA GTX 760 SC
2X Samsung Evo 840 250gb
Thermaltake TR2 RX 850w
Corsair H100i ( Nasty Thing )
Corsair SP-120 Rear Exhaust, AF-140 Top Exhaust
First mod to be done,,,, and soon! Is to get a real piece of glass cut for the window. Plastic windows SUCK!!! Next some sort of lighting. The GA-Z97X-SLI will have to go. To be replaced with a Asus Hero VII. Then get a real loop install! AIO's SUCK!!!!!!
H440RB as it is today:
5930K @ 4.5ghz
Tim: GC Extreme
MSI X99S Gaming 7
16gb Gskills RipJaws4 2400
EVGA GTX 980 Classified
Samsung XP941 Boot Drive
X2 Samsung Evo 840 250gb
WD Black 1TB
WD Green 500g
Corsair RM850w
XSPC RayStorm D5 Photon AX360 Water Cooling Kit
With a EK-Supremacy EVO CSQ Copper CPU Block
X3 Very Old Scythe 120mm 1850 rpm front intake fans. They can be very windy. smile emoticon
X3 XSPC 120mm fans that came with the kit in exhaust mode. Look to be very good fans.
Corsair SP-120mm Rear Exhaust
NZXT White Led Kit. Don't bother with one. There JUNK!
Outside of case painted with Krylon Semi Gloss Black, Red Tacky Plastic painted with Rustoleum Oil Rubbed Bronze. I have also removed the sound deadening martial from the front and top panels. Opened up the bottom of the front panel and also cut open a area on the top of the front panel for better air intake. I have also cut out the back of the top panel for better exhaust.
I have really been enjoying my NZXT Sibling Case's.
I bought three. I really like them. I like the shrouds. You can even use a non modular psu and get a very clean look. I love the footprint of the case with no 5.25" bays. On the negative side the 3.5" drive bays are pretty cheesy. Doesn't effect me because I don't use that feature. The other negative is that the paint is soft. All in all I really like the case.
