dident do anything disabling turbo. im stuck with keying in those settings ?
cpu mulitplier is the cpu ratio? Yes
if so its stuck on auto.wont seem to save changes for some resson when i key in the number 16x Try using the "+" and "-" keys.
allso for dram voltage i put in 1.55000 and im unsure what the cpunb voltage and cpu voltage u are refering to is on my bios..
i got cpu offset voltage ,cpu/nb offset voltage I would guess these are the main voltage adjustments for the CPU and CPUNB. Make some adjustement to the CPU offset voltatge and we will see if it shows up in CPU-z "CPU" tab. Again, you may need to use the "+" and "-" keys to increase them by small increments until you achieve the desired voltage or close to it.
nb voltage and nb 1.8v voltage..im not sure witch ones u are referin to.sorry Don't change these. I think they are referencing the "chipset" voltage.
arrrgg sorry im so silly i had to change the cpu level to auto again for me to change the cpu ratio..its on 16.0 now .im stil confused about the voltage for the cpu and cpu north bridge..iv got cpu ofset voltage witch is on 1.376 and the cpu/nb offset voltage on 2.487 nb voltage on 1.098 and nb 1.8v voltage 1.802 im still unsure witch cpu and nb values u are refering to sorry.
ok im changing the cpu ratio to 16.0
the dram voltage to 1.55000
and cpu ofset voltage to 375
Did you mean to say 375? That would fry it. I want the end result of the CPU voltage to be 1.375, not 375.
you said dont change the values beacause u think thay are refering to chipset voltage so im leaving the cpu nb volt alone for now.
No, I said the NB voltage and the NB 1.8 is referring to the chipset voltage, not the CPUNB.
i think thats what ur reffering to. and going from 1.144 to 1.25 seems alot.
1.225 would probably be enough with the ram at 1333 mhz.
will try to boot with this and see what happens
