- Feb 8, 2009
- Middle East
Hello...
As per my previous thread selecting a new cpu I got the I5 3570k , the Asus P8Z77-V PRO and Samsung Rams 2*4GBs .... on my way I also got a zalman water cooler.
(by the way the fallen capacitor didn't fall from the mb.)
anyhow...
Its oc time for me....
I got a little bit confused as the general spd mentioned in the system properties don't change...unlike the core 2 duo I had...
so...I used the mobo ocing program (AI Tweak), which oced the pc little by little, so far it reached 4.4GHZ more than that the pc would fail to start "I think its the ram"
questions:
1- using prime 95, Aida64 ,cpu-z and the mb Asus Suite, I got this pic:
PIC LINK
I got a warning from norton 360 regarding high temps (70 and up), and the temps as specified in the pic...I'm confused as part of the cpu temps are far too normal and the other part is far too hot!
2-what are the normal DDR 3 voltages (the seller who suggested buying those rams mentioned low voltage thresholds which allows more ocing), and what are the max temps?
3- I'm getting strange CPU:FSB ratio 1:6 .... is that ok? how can I oc further since the rams seem to limit any further ocing.
4- How to oc the nominal speed of the cpu (meaning not to wait for good temps to raise the multiplier, like the core 2 duo used to do either idle or max)
5- I "heard" somewhere about triple channel for the ddr3, does it need 3 pcs of ram to run? and what is the arrangement of rams to get a triple channel?
anyhow...
questions:
PIC LINK
