- Mar 26, 2003
- North America
I'm starting this thread because it is driving me NUTS that seemingly nobody has overclocked a Penryn quad on anything better than a P35/G35 chipset. Why spend $350 on a processor if you're gonna stuff it on a $89 motherboard?
(no offense intended to those who are stuffing said $300+ processors on said $89 motherboards )
Anyway, much props to the Tank Guys for having the Q9450 in stock, I ordered one ten minutes ago and this thread will be my log of exactly how it does on my X38-DS4 under an Apogee GT and dual 120mm rad.
To give you some background on my motherboard: I've had it running 575FSB with entirely stock voltages across the board on an E6850, with exception to the DDR voltage as my poor Ballistix DDR2-800 needed some help to hit 1150 stabily
So, I know the board is more than capable of hitting uber FSB's, so the only drawback now should be the processor itself.
Let the saga begin!
Edit
Shiggy requested that I pop into this first post and put up some baseline information so it's easier to find later in life when the Q9450 is "old news" So...
Q9450 SLAWR 2.66Ghz/12Mb/1333
FPO:L803A55 Batch: 357357
I never tested the temps stock, but at 3.2Ghz (400 x 8) on stock volts the two working thermal sensors indicated 44* after about 45 minutes of 2 x Orthos with 10k in-place FFT's at priority 10.
TankGuys Sales said:Order Number: xxxx
Detailed Invoice: https://www.tankguys.com/account_history_info.php?order_id=xxxx
Date Ordered: Thursday 27 March, 2008
Hello from Albuquerque @ OCForums.com
Products
1 x Core 2 Quad Q9450 2.66 Ghz (Yorkfield) TRAY/OEM (EU80569PJ067N) = $359.99
Federal Express (1 x 1lbs) (Home Delivery (2 days)): $11.05
Sub-Total: $359.99
Total: $371.04
Let the saga begin!
Edit
