Tried setting Dram Timing Mode to "auto" but PC wouldn't load. Black screen saying "The file is possibly corrupt. The file header checksum does not match the computed checksum". I set it back to Manual and it works ok.
Memclock Value doesn't have "auto" There are 4 choices of speed - 800, 667, 533 and 400. I set Memory Clock Mode to "auto" tho and it loads up OK and doesn't change the Dram Frequency (stays at 667 with the FSB at 250), so I guess default must be 500... or Dram Frequency only autos up higher when Timings are on auto (or set at a lower/quicker(?)) speed. If I set both Dram Timing Mode and Memory Clock Mode to "auto" I get the same "Checksum" error above.
CPU-NB is currently still set to 1.23125. The next step up is 1.23750.
As far as the overclock wall, my max FSB (as calculated by Dolk's method) was 270, so a current FSB of 250 looks pretty good to me. 25% increase + the extra Core and L3 isn't bad for £0
(assuming it passes a longer test, of course)
At the moment my CPU Temp max's at 52c under load.
My current CPU Over Voltage is 1.4v.
Should I be upping that to 1.5?
