- Oct 14, 2007
I saw this extremely useful tool at hwbot. After you check it out, leave any feedback you may have in the thread @ HWBot.
W1zzard said:
OC Snap from TechPowerUp, is a lightweight utility that allows you to launch a set of other applications, and pre-program the position of the windows of the launched applications. Multiple instances of the applications, with their desired tabs can be programmed.
This utility is particularly useful for professional overclockers and PC enthusiasts, to launch key applications such as CPU-Z and GPU-Z after achieving an overclocking or performance measurement worth sharing with others.
After scoring your feat, simply run the application to load your window location profile and use the same utility to take a screenshot.
Hiwa also made a video, showing it in action:
Download: Beta build
Would be cool to get some feedback on this, what extra features would be useful etc.
