I recently upgraded my computer, and it seems to be much less stable than it was.
Specifically, with the new configuration, when I boot the computer, it will often fail to POST, reboot, and then POST successfully. Occasionally, it has refused to POST at all. I'm wondering if my PSU might perhaps be insufficient for my setup.
I also had a situation where my WDC1002FAEX Caviar Black 1TB hard drive caused the BIOS to hang during POST whenever it got to the part where it identifies the device connected to whichever SATA port the caviar black drive is plugged in to. However, I hotplugged the drive, and now it works fine, both hotplugged and during boot-up. I'm doing an RMA with western digital (the drive was empty when it failed, how often does that happen?)
Unchanged from old to new config:
Mobo: Gigabyte GA-H55M-USB3 v 2.0, latest BIOS firmware (F11 I think)
CPU: Intel core i3 560 Clarkdale 3.33 GHz
PSU: Antec Earthwatts Green EA-430D 430W continuous rated
Optical Drive: Lite-ON Black 12x Blu-Ray Burner IHBS112-29
Hard drives: Hitachi 1TB 7200 RPM SATA
Maxtor 200GB IDE
Western Digital Caviar Green 2TB WD20EARS
Card Reader: AFT XM5U All-in-one USB 2.0 Card Reader
2x 120mm fan, 1x 80mm fan
Parts in old config that were removed:
RAM: G.SKILL 4GB (2 x 2GB) DDR3 1333 (PC3 10666) F3-10600CL9D-4GBNT
G.SKILL 2GB (2 x 1GB) DDR3 1333 (PC3 10666) F3-10666CL9D-2GBNQ
GPU: Asus Nvidia Geforce 210 Silent
SSD: Kingston SSDNow V+ Series SNVP325-S2/64GB
Parts added to the new Config:
RAM: CORSAIR XMS3 16GB (4 x 4GB) DDR3 1600 (PC3 12800) CMX16GX3M4A1600C9
GPU: ZOTAC ZT-20202-10L GeForce GT 220 512MB 128-bit DDR2
SSD: Corsair Force Series 3 CSSD-F90GB3-BK 2.5" 90GB SATA III
Hard Drive: Western Digital Caviar Black 1TB WDC1002FAEX
The system had been running stable for about 8 months. I run linux Ubuntu 10.04 Lucid, and my computer runs 24/7. The only overclocking I did was to enable the XMP profile for the Corsair ram, enabling it to run at 1600 MHz.
How much additional power does having lots of ram consume? Which rail does it come from? Neither the old nor the new graphics card had an external power connector, so I assumed that neither drew much power.
I was able to get the system stable again by removing two sticks of the new corsair ram, so now I'm running on 8GB of ram, but I'd like to get the full 16GB working. The Mobo is speced to support a max of 16 GB of ram, although this specific set of ram isn't on the QVL (the largest config on the QVL is only 4GB), the CM3X8GX3M4A1333C9 is, which is a similar model number to mine.
I've run memtest86+ on the ram, and everything comes out clean. The video card I pulled from another working system. Is my mobo bad? Or the PSU? any ideas?
Maxtor 200GB IDE
