- Apr 14, 2011
The specifications of GAK-CORE2 are
Biostar TP45HP
Core 2 QUAD q9650 (Thanks gsrcrxsi!)
g.skill F2-6400CL5D-4GBPQ 8GB total
NZXT RC-RST40-01 Heatpipe cooler (looks like i can change out the fan for a better one if i wanted to)
Corsair CX500 power supply
Q9650 comes in the mail and i install it in GAK-CORE2, reset bios, and push it straight up to 445mhz. No go as i get a blue screen. So after adjusting voltages here and there and eventually getting it to boot at 3.8ghz. While trying to get to 4ghz, i found that if i had left speed step and cie support disabled, only cores 0 and 1 would be at 3.8ghz and cores 1 and 2 would be at 2.5ghz. re-enabled the two power saving features and now its a processor fully running at 3.8ghz. As i type this, i currently have prime95 stress testing it to see if its stable. I also enabled thermal throttling too but i dont see it throttling down speeds...yet.
for voltages, i have the processor sitting at around 1.3v vcore and around 1.2v FSB. MCH(1.18v) and DDR (2.0v) are on auto since i see no reason to adjust them myself and since they are already in the safe limits.
Does anyone know what the max unsafe temperatures are for this processor? one of the cores just hit 72c and i read that 45nm processors can degrade at those temperatures while others say 80c or 90c.
- - - Updated - - -
UPDATE
prime95 just crashed. increasing vcore*
Also, does anyone know which voltages i should change speficially? or what order i should go in? i am able to boot into windows but some programs or even windows crash/bsod so im not sure if i need more vcore or more fsb or mch voltages.
Biostar TP45HP
- - - Updated - - -
UPDATE
