- May 26, 2004
- San Diego, CA
I keep getting excuses from him, its really p issing me off.
2 weeks would be extremely expedient by chilly's standards.proth said:X, Killer OC on Air man.. Good luck with Chilly. Havn't heard a peep outta him in 2 weeks. He missed 3 ship comittments to me already.
I'd have to research the type of processor your using to fully appreciate it's "behavior" ("Bad processor did I catch you Thermal Throttling yourself again! Go to your Box!") I'm also unfamiliar with motherboard for 805s. Aren't these usually Dual Socket boards? Tyan etc. From what I know of Tyan they probably have some solid power stages on their boards. I don't thjink that's the issue I do think it may be related to your Antec 430W PSU, which may be underpowered for the application, especially if the modo is dual socket.goog` said:If they have this limit on the 12 volt rail why do they not just revise the specs so that voltage s fed to each key componet via a seprate feed to avoid excessive drain and strain. Have a led directly to the cpu, videocard/ram/chipset ect. Would such a system not allow for smaller and sturdier regulation circutry.
Also From what I got for you blurbs liquid is that the older prescotts for 478 and early 775 were limited not only by poor power supply but insufficient voltage regualtion. I'm suffering from a lack of power on my pent d 805 system with a motherboard built using 478 technoligy could the voltage drops be caused by insufficient regulation circutry as it is by my termaltake 430w with 18v @ 12 or is the powersupply the only problem or would futher increase in power be offset by powerloss in the motherboard
Ever seen the movie "The Money Pit"? That's the 2 weeks he meant Chilly does great work, but so do others.2 weeks would be extremely expedient by chilly's standards.
Liquid3D said:Your Presler is a hungry beast, and just as an experiment if you can borrow an older PSU pre ATX 2.01 / EPS 2.1 guide revisions with at least 33A on the 12V Rail this will at least answer the question if in fact th PSU is the culprit.
Another problem may be total drain on the PSU; if your watercooling the PSU what else are you watercooling? Between case-fans, radiator-fans and pump/s this can drain 12V rails and your Tagan may be fine with a minimal number of compoments, but the added H20 hardware while necessary, may be stressing the PSU in combination with Presler.
The other thoughtbn that came to mind was BSOD's are often memory related and the randomness of your re-bott may not be so. I would try running the PC2-8000 on SPD (or AUTO depending on the BIOS). These are not modules that do well under manual settings running 1000MHz regardless of timings because at this speed they run better at the manufactuers pre-progammed (SPD) timings. They tested or stability at 1000MHz on SPD. The same IC's in your PC2-800 are most likely those found in all PC2-6400 as well, these simply binned highest. This is their operational ceiling at loose timings.
Try SPD first, CMD2 and if the DDR voltage is above 2.15V try putting it on AUTO as well.
Sentential said:]It must have both a 24pin ATX, 8pin P4 connector, and a 4 pin molex or adaptors needed to convert improper connections to the ones listed here ... Yes you MUST connect ALL 3 power connectors to get stable results
