- Nov 3, 2008
I need a good program for getting temp readings. I just want to verify sandra readings there are a lot of good progs out there but I need something that I do not need to adjust the offsets as I do not know if the readings are correct.
Specs
MB Biostar TA790GX A2+
CPU 5200+
Vid Sapphire 3850
6Gigs ram
Vista 32
Linux 64 (why I do not know)
160 gig uata backups
2X sata 160Gig WD in raid 1
Sandra always reads 26-28C cpu temp
Any other prog I try gives wacky reads and I dont know what offset to use
Specs
CPU 5200+
Vid Sapphire 3850
6Gigs ram
Vista 32
