G'day Team, Lawry here.
I am a recent convert to the PC master race and decided what better faction to join than the ROG.
Spec's are:
Motherboard - ROG STRIX Z370-E GAMING
Processor - I5-8600K
Memory (part number) - F4-3000C16D-16GTZR (16Gb of GSkill Trident 3000)
Graphics Card #1 - STRIX-GTX1080-A8G-GAMING
Monitor - XG35VQ (ps, this monitor is an absolute eye-gasm. Love it!!)
Storage #1 - WD Blue SSD 256Gb
Storage #2 - ST2000DM006 (Barracuda 2TB)
CPU Cooler - MasterLiquid ML120L
Case - Fractal Meshify C (With 5 x ThermalTake Riing 120mm Fans, 2 drawing air in (one on the radiator) and 3 set to blow)
Power Supply - eVGA 220-G3-0750-X4 750W
Keyboard - ROG Strix Flare
Mouse - ROG Strix Evolve
OS - Windows 10
So I built up my first rig and immediacy wanted to OC it, as one who has never done so does... so I strapped on GPU Tweak II and clicked the overclocked option on the 1080, and then using the CPU multiplier in Intel Extreme Tuner slid the core multiplier up to a very mild 40 (4Ghz) with the Cache @ 38 (3.8Ghz) (NB - as there was a similar difference at stock so I figured leave the gap rather than matching the cache to the cpu?) and my system seems to work well (max temp on CPU benchmark on IET was 58 degrees C.
My questions to OC gods are as follows:
1 - Should I always leave these settings on or just dial it up to 11 for gaming (I will be using this PC as a daily driver as well for doc processing and web work with a bit of Photoshop thrown into the mix too)
2 - Have I done this right and if I haven't, what would you recommend
3 - Finally, how far can I push this thing before it turns into a flaming pile of RGB.....
4 - Is there anything else that I should add to this build??
I look forward to your replies team!
- Lawry
Spec's are:
OS - Windows 10
- Lawry
