- Jun 22, 2005
- Miami Beach
This was a fun board to overclock. I must have tried about 30 different modded BIOS. I liked Tic Tac's Black Mantaray the best.
Ok, thanks for all the nice words and recommendations. But right now, all I want to know is: What in god's name do I have to do to get Windows 7 installed? Do you guys think getting a new SATA controller might fix the problem? And how comes setup doesn't even recognize my USB ports? This is killing me...
Use the Win7 to upgrade or you will have to use the sata drivers from XP or Vista. It is very hard to install because drivers were never written for the sata chipset. I had to install Vista and upgrade from there to get the raid working. Oh by the way 7-3-3-2.5 is as fast as any ram will run on that platform. Other settings might work but they will be slower because it needs the wait cycles to fully read the data.
Easiest way to tell is to run Everest home edition. 7-3-3-2.5 will usually run higher MHZ than tighter timings. When both crap out the 7-3-3-2.5 will have higher bench scores. I ran 5-2-3-2 memory (had to flash SPD to get 2.5) at the looser timings because it was actually faster.Everything I have read, and have been told, says that on an nforce2 board tRAS should be 11 for best performance.
When I was cleaning the spare room and decieding to junk NF7-S only missing the hd
I should remove the OCZ Platinum sticks and dump it.
Im in NY, if your dumping it, Ill take it off your hands.
