- Mar 24, 2004
Finally! It's done! Full formatted, cleaned and everything reinstalled. Here it is. Pics of the beast with specs, overclocks, and benchmarks!
Specs:
-Thermaltake XASER, Armor Series VA8000BWS
-ASUS A8N-SLI Deluxe Socket 939 NVIDIA nForce4 SLI
-AMD Dual Core Opteron 170 939 Socket
-Thermaltake 120mm SmartFan on top of an XP-120 Heatsink
-eVGA GeForce 7800GT PCI-e 256mb Co (Copper heatsink / 517 model)
-Corsair 2GB Kit DDR500 XMS4000 Memory w/Platinum Heat Spreader (2x1GB)
-Western Digital Raptor WD740GD 74GB 10,000 RPM 8MB Cache Serial ATA150
-Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply
-Creative Sound Blaster X-Fi XtremeMusic 8 (7.1) Channels 24-bit 96KHz
-ASUS Black E-IDE/ATAPI DVD Burner 5X DVD-RAM Write
-Logitech 961265-0403 QuickCam Pro 4000 1.3MP Effective Pixels
-Rounded UV Reactive Cables
-2x UV Cathode Lights
-2x 120mm case fans (intake and exhaust)
Total Cost - $1800 to me ($2000 with case and burner, were free for Christmas)
--- Overclock ---
CPU:
Opteron 170 Dual Core - CCBWE 0546 XPMW
Default Clock: 2.0ghz
Default Multiplier: 10x
Default FSB: 200mhz
Default Idle Temp: 29c
Default Load Temp: 42c
Overclocked:
Clock: 2.75ghz
Multiplier: 10x
FSB: 275fsb (4x HTT effective running speed 2200mhz HTT)
Voltage: 1.5v
Idle Temp: 34c
Load Temp: 45c
Overclocked benchmarks in Sandra 2003 R3:
Arithmetic:
Dhrystone ALU : 24778 MIPS
Whetstone iSSE3 : 11435 MFLOPS
Multimedia:
Integer x4 aEMMX/aSSE : 51626 it/s
Float x4 iSSE2 : 56775 it/s
RAM:
Corsair 2x1GB ddr500
Default FSB: 250mhz
Default timings @ 250mhz: 3-4-4-8-2T
Voltage: 2.6v
Overclocked (still tweaking atm):
FSB: 230mhz
Timings: 3-3-3-6-1T
Voltage: 2.8v
RAM Bandwidth Int Buff'd iSSE2 : 6512 MB/s
RAM Bandwidth Float Buff'd iSSE2 : 6449 MB/s
Video:
eVGA GeForce 7800GT Co
Default Core: 470mhz
Default Mem: 1.1ghz
Overclock:
Core: 490mhz
Mem: 1.2ghz
Benchmark Results:
3dmark05: 8135
3dmark03: 17600
Aquamark 3: 98274
CS:S Stress @ 1024x768 - High everything 4xAA 8xAF dxlevel 9.0+ Full HDR:
212.50fps
There's my system! Thought I'd share my upgrade with you. The pictures are *okay* I will put up higher quality when my brother visits with his digital cam!
Specs:
--- Overclock ---
CPU:
Default FSB: 200mhz
Overclocked:
Clock: 2.75ghz
Multiplier: 10x
Voltage: 1.5v
Idle Temp: 34c
Load Temp: 45c
Arithmetic:
Multimedia:
RAM:
Default FSB: 250mhz
Voltage: 2.6v
FSB: 230mhz
Timings: 3-3-3-6-1T
Voltage: 2.8v
Video:
Default Mem: 1.1ghz
Overclock:
Core: 490mhz
Mem: 1.2ghz
Benchmark Results:
3dmark05: 8135
3dmark03: 17600
Aquamark 3: 98274
212.50fps
