- May 29, 2005
Hey all,
I'm fresh out of ideas to what is causing packet loss/lag spikes when I am playing PC games. The issue doesn't appear [to me] when I play single player, or if I am hosting a co-op game in BF3, so it must be networking related, as the person who connected to my co-op game told me the things he was experiencing and it was the same that I see.
The issue can be described as running/driving in BF3 (for example, I've tested with also BF:BC2 and TF2 and it is still present) and it feels like getting stuck randomly, or while turning it lags and puts me back to where I was. It happens maybe 5-10% of the time while playing and started a little over a month ago. If I run a ping <insert IP here> -t during the gameplay when I lag spike I see that it gives either a huge jump or no return at all.
What I have done and didn't see any difference:
- Tried using the two different NICs on my MIVE
- Updated Network drivers for my MIVE
- Different OS install - even had one that I hadn't used since before the issue started happening
- Plugged directly into the modem skipping my router and/or switch
- Rebooted modem/router/switch/pc numerous times (and left unplugged for hours at a time just to test)
- Changed network cable from Cat5e to Cat6
- Had my ISP (WOW) install one of their modems yesterday (I've been using a self-purchased motorola SB6120 for 6 months before it started happening) - no change
- The guy that came out yesterday that installed just ran a couple speed tests from speedtest.net and it came back as the full 50/5 and he said 'well if I got you surfing that's all I'm here for' and left
- Contacted one of the guys from the NOC for WOW and he ran some tests and didn't see any bad signal levels/etc apparently
I'm at a complete loss. Other than purchasing/finding a PCI-E NIC to squeeze between my two triple-slot 580s.
