- Oct 7, 2003
- Vienna, Austria
First I have to say that I am from Austria (Europe), and so my English maybe isnt perfect.
I have a Creative GeForce 4 Ti 4800 (4600 w/ 8x AGP) w/ 128MB RAM. I couldnt overclock it yet, because the GPU has a very bad cooling and the RAM-chips arent cooled at all. My Qustion: Do you think, I should use a Zalman Heatpipe ZM80C-HP VGA-Cooler + Fan ZM-OP1 (mounted directly on the cooler) or a conventional cooling soltion? What do you think cools the GPU and RAM better?
How high do you think I would get w/ the Zalman w/o getting artifacts?
I also have found a conventional cooling solution: The Thermaltake G4-Copper-Cooling set. The problem is, the RAM coolers in this set are 63,48 mm X 21mm X 13,5 mm big, but I only need 48x12mm to cover two RAM chips at once (they are 12x12mm big and there is a gap of 24mm between two chips). So I dont know, if It is safe to stick the coolers on the chips or if there is a risk that they drop down on some day. I could also use 20x12.6x8mm Aluminium RAM-coolers if they stick better.
How far do I think I can get w/ the G4 cooling set w/o getting artifacts? Do you think, it would make a difference when I use the Aluminium RAM-coolers instead of the copper?
My Graphics card:
Creative 3D Blaster 4 Ti 4800, GeForce4 Ti4600 8X AGP
http://uk.europe.creative.com/products/product.asp?prod=432
Cooling solution w/ Zalman:
Zalman Heatpipe ZM80C-HP:
http://www.zalman.co.kr/english/product/ZM80C-HP.htm
Fan Zalman ZM-OP1:
http://www.zalman.co.kr/english/product/ZM-OP1.htm
Conventional Cooling:
Thermaltake GeForce 4 A1349 copper cooling set:
http://www.thermaltake.com/products/chipset/g4.htm
20x12.6x8mm Aluminium RAM-coolers (German):
http://www.xtrem.biz/catalog/product_info.php?products_id=537
My Graphics card:
Fan Zalman ZM-OP1:
