- Apr 11, 2012
did you put this computer together yourself? is there thermal paste between the cooler and the cpu? it takes just a little bit, about the size of a small pea. what cpu cooler are you using? AS Earthdog said, you're already at the high temperature mark, so you need a better cooling solution.
