sanderestonia
- Dec 29, 2012
No one can say if 'your' cpu voltage needs to be raised. YOU need to run Prime 95 in Blend mode for at least 2 hours and see if P95 fails in some way or the temps rise too greatly, to know if the cpu has enough voltage to run that speed or if the temps get too hot to be safe to even add more cpu voltage if P95 is failing Blend mode.
That cpu at 2.8Ghz on air is pretty close to being maxed now.
OP you need a non-stock cooling solution if you are going to OC, particularly older, hot parts.
I ran P95 and my CPU tempeture raised CORE 0-91c and CORE 1-88c immediately and I changed it back to 2.50GHz I dont want to blow up my computer lol, but what is the best OC for this? 2.70MHz or 2.60MHz? In BIOS I changed CPU freguency and CPU Clock Radiot
I need change there something more ? And also why my GPU tempeture is so high? When Im running some game then it raises like to 60c ..that worries me.
