Overclocking a Pentium Dual-Core E6500
Mr.Weston
New Member - NEED HELP OC Asus P5P43TD motherboard
I would first like to say hello. I am a new member and I Need help with overclocking my CPU in Bios
the specs for my computer are as followed:
Asus P5P43TD Motherboard
Intel Pentium Dual-Core E6500 Wolfdale 2.93GHz 2MB L2 Cache LGA 775 65W
Dual-Core Processor
Tech Spec
Core
Wolfdale
Multi-Core
Dual-Core
Name
Operating Frequency
2.93GHz
FSB
1066MHz
L2 Cache
2MB
Manufacturing Tech
45 nm
64 bit Support
Yes
Virtualization Technology Support
Yes
Voltage
0.85V – 1.3625V
Thermal Design Power
65W
Kingston HyperX 2GB 240-Pin DDR3 SDRAM DDR3 1800 (currently running on board
at 1643mhz)
2GB
Speed DDR3 1800
Cas Latency 9
Voltage 1.7V - 1.9V
ECC No
Buffered/Registered Unbuffered
HIS H467QR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16
Chipset Manufacturer:ATI
Core Clock:750MHz
Stream Processors:320 Stream Processing Units
Effective Memory Clock:1600MHz
(which is clocked with their catalyst)
Western Digital Caviar Green WD5000CSRTL 500GB 7200 RPM 16MB Cache SATA 3.0Gb
APEVIA ATX-AQ700W-BK 700W ATX12V / EPS12V SLI Ready CrossFire Ready Power Supply
I am running Windows 7 32bit and I also tried to install the Turbo Key but it does not work on my system.
I don't know if this would help at all but if someone could inform me I would appreciate it. I heard this can get up to 3.66GHz if you up the FSB to 333 but I am looking to only go to 3.52GHz.
I hope someone could walk me through the BIOS settings so I could tweak everything correctly & ensure stability.
I have built some computers before but never had the opportunity to overclock, hopefully someone could walk me through the steps. Thanks.
Mr.Weston
No need to create two threads... its just going to get confusing for all of us. ;)
Have you checked out the overclocking guide (link in my signature)? Thats the first place I would look...thats your walkthrough really.
AS far as cookie cutter settings, it may not work for your setup is the problem...
