- May 10, 2009
400FSB strap on P45 chipset is generally garbage. 333 is usually your best bet.
More NB volts may well be the answer. Definitely check the RAM voltage, timings, and speed.
What's your PLL set to?
What revision UD3P is that?
As to the VID/max volts question, VID is completely unrelated to maximum safe voltage. It is the range that the socket and VRM controller will allow a CPU's internally pulled LOW and HIGH VID pins to set the voltage to.
Hence, it's a per-socket (or even more specifically, per Intel VRM Spec) rating.
