ejohanss said:pscout:
Once my 7800GTX-KO gets here, and I disable onboard graphics, do you think I have a shot, or is it the 945G chipset itself.
Thanks.
bignick said:Like I said before I have had no trouble with the P5LD2, I have Oc'ed a 630, 805 and 930 on it and all went there max on air. I did at first I have issues before I updated to the 1103 BIOS. Before I did that it seems the board had a 220-230 max FSB depending on the chip. I've had this board at 275fsb with no issues.
bignick said:I'm not really sure what it's limit is but that was my 930's limit on air. I could push it higher but it would throttle after 275FSB.
pscout said:I think batboy runs his 940 on that abit? ... find his thread from early january when we were all playing with the newly arrived presslers. I recall the abit's having mem compatability issues but i am no expert on them ... all my 800/900 DC rigs are asus.
P5WD2 is a great board ... i have 2 basic models as well as the -p, and -E. The plain p5wd2 OC's my 920's and 930's as well as the -P and -E. The only thing better on the -E (ignoring extra features) is that it will give you 2.4 VDDR whereas the other p5wd2's will only provide 2.3V. If Conroe was not almost here, i would be tempted to build another DC rig on the plain p5WD2. Unless you need the features, I would not bother with the -p and -E versions.
If you go with the p5ld2, i would say your probability of a good oc is low ... i have 3 of them ... i was hoping they would be cheap folding rigs but was dissappointed ... however they are just fine for my 830's.
