Darkling63
- Jan 6, 2018
Hey!
I have OC problems with my Ryzen 5 1600 on Asus Prime X370-Pro for the last 4 bios versions (on the newest one, 3402, also). I set 3.8GHz, voltage on 1.38 and CPU LoadLine Calibration on Level 3. When i saved changes and left bios i runned OCCT. Voltages were jumping about 1.46V after only 20 seconds (on large data!). LoadLine Calibration on level 2 and lower Voltage didn't fix the problem, it still was about 0.1V more than I set.
Does anybody on this forum have that motherboard? Have you overclocked your CPU on the newer bios versions? What were your results?
PS Also on auto settings voltages are higher than they should be - about 1.3, 1.32V.
