OverClocking Such A Old Crapper :)
jackiodwil
Hello guys my pc is really old and i cant cant a new one but i would like any kind of help i can get 2 get it boosted >.< here are the specs...
Code:
CPU-Z
Binaries
CPU-Z version	1.67.1.x64
Processors
Number of processors	1
Number of threads	4
APICs
Processor 0
    	-- Core 0
        	 -- Thread 0	0
    	-- Core 1
        	 -- Thread 0	1
    	-- Core 2
        	 -- Thread 0	2
    	-- Core 3
        	 -- Thread 0	3
Timers
    	ACPI timer	3.580 MHz
    	HPET timer	25.000 MHz
    	Perf timer	2.441 MHz
    	Sys timer	1.000 KHz
    	BCLK timer	333.33 MHz
Processors Information
Processor 1	ID = 0
    	Number of cores	4 (max 4)
    	Number of threads	4 (max 4)
    	Name	Intel Core 2 Quad Q9300
    	Codename	Yorkfield
    	Specification	Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
    	Package (platform ID)	Socket 775 LGA (0x4)
    	CPUID	6.7.7
    	Extended CPUID	6.17
    	Core Stepping	M1
    	Technology	45 nm
    	TDP Limit	95 Watts
    	Core Speed	2499.7 MHz
    	Multiplier x Bus Speed	7.5 x 333.3 MHz
    	Rated Bus speed	1333.2 MHz
    	Stock frequency	2500 MHz
    	Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
    	L1 Data cache	4 x 32 KBytes, 8-way set associative, 64-byte line size
    	L1 Instruction cache	4 x 32 KBytes, 8-way set associative, 64-byte line size
    	L2 cache	2 x 3072 KBytes, 12-way set associative, 64-byte line size
    	FID/VID Control	yes
    	FID range	6.0x - 7.5x
    	Max VID	1.200 V
Chipset
Northbridge	NVIDIA nForce 780i SLI SPP rev. A2
Southbridge	NVIDIA nForce 780i SLI MCP rev. A3
Graphic Interface	PCI-Express
PCI-E Link Width	x16
PCI-E Max Link Width	x16
Memory Type	DDR2
Memory Size	8 GBytes
Channels	Dual
Memory Frequency	399.9 MHz (5:6)
CAS# latency (CL)	5.0
RAS# to CAS# delay (tRCD)	5
RAS# Precharge (tRP)	5
Cycle Time (tRAS)	18
Bank Cycle Time (tRC)	22
Command Rate (CR)	2T
Memory SPD
DIMM #	1
    	SMBus address	0x50
    	Memory type	DDR2
    	Module format	Regular UDIMM
    	Manufacturer (ID)	Corsair (7F7F9E0000000000)
    	Size	2048 MBytes
    	Max bandwidth	PC2-6400 (400 MHz)
    	Part number	CM2X2048-6400C5
    	Number of banks	2
    	Data width	64 bits
    	Correction	None
    	Nominal Voltage	1.80 Volts
    	EPP	no
    	XMP	no
    	AMP	no
JEDEC timings table	CL-tRCD-tRP-tRAS-tRC @ frequency
    	JEDEC #1	4.0-4-4-13-15 @ 270 MHz
    	JEDEC #2	5.0-5-5-18-22 @ 400 MHz
DIMM #	2
    	SMBus address	0x51
    	Memory type	DDR2
    	Size	2048 MBytes
    	Number of banks	2
    	Data width	64 bits
    	Correction	None
    	EPP	no
    	XMP	no
    	AMP	no
DIMM #	3
    	SMBus address	0x52
    	Memory type	DDR2
    	Size	2048 MBytes
    	Number of banks	2
    	Data width	64 bits
    	Correction	None
    	EPP	no
    	XMP	no
    	AMP	no
DIMM #	4
    	SMBus address	0x53
    	Memory type	DDR2
    	Size	2048 MBytes
    	Number of banks	2
    	Data width	64 bits
    	Correction	None
    	EPP	no
    	XMP	no
    	AMP	no
Monitoring
Mainboard Model	P5N-T DELUXE (0x0000033B - 0xBE5D88A0)
LPCIO
LPCIO Vendor	ITE
LPCIO Model	IT8718
LPCIO Vendor ID	0x90
LPCIO Chip ID	0x8718
LPCIO Revision ID	0x4
Hardware Monitors
Hardware monitor	ITE IT87
    	Voltage 0	1.22 Volts [0x4C] (CPU VCORE)
    	Voltage 1	3.10 Volts [0xC2] (VIN1)
    	Voltage 3	4.78 Volts [0xB2] (+5V)
    	Voltage 4	11.78 Volts [0xB8] (+12V)
    	Voltage 6	-4.16 Volts [0x41] (-5V)
    	Voltage 7	4.87 Volts [0xB5] (+5V VCCH)
    	Voltage 8	3.20 Volts [0xC8] (VBAT)
    	Temperature 0	28°C (82°F) [0x1C] (TMPIN0)
    	Temperature 1	45°C (113°F) [0x2D] (TMPIN1)
    	Temperature 2	23°C (73°F) [0x17] (TMPIN2)
    	Fan 0	1654 RPM [0x198] (FANIN0)
    	Fan 1	3358 RPM [0xC9] (FANIN1)
    	Fan 3	1436 RPM [0x1D6] (FANIN3)
    	Fan PWM 0	99 pc [0x7F] (FANPWM0)
    	Fan PWM 1	99 pc [0x7F] (FANPWM1)
    	Fan PWM 2	99 pc [0x7F] (FANPWM2)
Hardware monitor	Analog Device ADP3228
    	Current 0	15.01 Amps [0x74] (CPU)
    	Power 0	17.80 W [0x1033] (CPU)
Hardware monitor	ACPI
    	Temperature 0	40°C (104°F) [0xC3C] (THRM)
Hardware monitor	NVIDIA I/O
    	Temperature 0	52°C (125°F) [0x34] (TMPIN0)
Hardware monitor	NVIDIA NVAPI
    	Voltage 0	1.10 Volts [0x44C] (VIN0)
    	Fan PWM 0	50 pc [0x32] (FANPWMIN0)
PCI Devices
Description	Host Bridge
Location	bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03A1
    	Revision ID	0xA2
Description	RAM Memory Controller
Location	bus 0 (0x00), device 0 (0x00), function 1 (0x01)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03AC
    	Revision ID	0xA1
Location	bus 0 (0x00), device 0 (0x00), function 2 (0x02)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03AA
    	Revision ID	0xA1
Location	bus 0 (0x00), device 0 (0x00), function 3 (0x03)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03A9
    	Revision ID	0xA1
Location	bus 0 (0x00), device 0 (0x00), function 4 (0x04)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03AB
    	Revision ID	0xA1
Location	bus 0 (0x00), device 0 (0x00), function 5 (0x05)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03A8
    	Revision ID	0xA2
Location	bus 0 (0x00), device 0 (0x00), function 6 (0x06)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03B5
    	Revision ID	0xA1
Location	bus 0 (0x00), device 0 (0x00), function 7 (0x07)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03B4
    	Revision ID	0xA1
Location	bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03AD
    	Revision ID	0xA1
Location	bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03AE
    	Revision ID	0xA1
Location	bus 0 (0x00), device 1 (0x01), function 2 (0x02)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03AF
    	Revision ID	0xA1
Location	bus 0 (0x00), device 1 (0x01), function 3 (0x03)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03B0
    	Revision ID	0xA1
Location	bus 0 (0x00), device 1 (0x01), function 4 (0x04)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03B1
    	Revision ID	0xA1
Location	bus 0 (0x00), device 1 (0x01), function 5 (0x05)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03B2
    	Revision ID	0xA1
Location	bus 0 (0x00), device 1 (0x01), function 6 (0x06)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03B3
    	Revision ID	0xA1
Location	bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03B6
    	Revision ID	0xA1
Location	bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03BC
    	Revision ID	0xA1
Location	bus 0 (0x00), device 2 (0x02), function 2 (0x02)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03BA
    	Revision ID	0xA1
Description	PCI to PCI Bridge
Location	bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x03B7
    	Revision ID	0xA1
Location	bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0369
    	Revision ID	0xA2
Description	PCI to ISA Bridge
Location	bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0360
    	Revision ID	0xA3
Description	SMBus Controller
Location	bus 0 (0x00), device 10 (0x0A), function 1 (0x01)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0368
    	Revision ID	0xA3
Description	USB Controller (OHCI)
Location	bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x036C
    	Revision ID	0xA1
Description	USB 2.0 Controller (EHCI)
Location	bus 0 (0x00), device 11 (0x0B), function 1 (0x01)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x036D
    	Revision ID	0xA2
Description	IDE Controller
Location	bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x036E
    	Revision ID	0xA1
Location	bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x037F
    	Revision ID	0xA3
Location	bus 0 (0x00), device 14 (0x0E), function 1 (0x01)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x037F
    	Revision ID	0xA3
Location	bus 0 (0x00), device 14 (0x0E), function 2 (0x02)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x037F
    	Revision ID	0xA3
Location	bus 0 (0x00), device 15 (0x0F), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0370
    	Revision ID	0xA2
Description	Multimedia device
Location	bus 0 (0x00), device 15 (0x0F), function 1 (0x01)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0371
    	Revision ID	0xA2
Description	Bridge device
Location	bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0373
    	Revision ID	0xA3
Location	bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0378
    	Revision ID	0xA3
Location	bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0377
    	Revision ID	0xA3
Location	bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x05B1
    	Revision ID	0xA2
Location	bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x05B1
    	Revision ID	0xA2
Location	bus 2 (0x02), device 2 (0x02), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x05B1
    	Revision ID	0xA2
Description	OHCI FireWire Controller
Location	bus 5 (0x05), device 11 (0x0B), function 0 (0x00)
Common header
    	Vendor ID	0x1106
    	Model ID	0x3044
    	Revision ID	0xC0
Location	bus 6 (0x06), device 0 (0x00), function 0 (0x00)
Common header
    	Vendor ID	0x11AB
    	Model ID	0x6121
    	Revision ID	0xB2
Description	VGA Controller
Location	bus 7 (0x07), device 0 (0x00), function 0 (0x00)
Common header
    	Vendor ID	0x10DE
    	Model ID	0x0625
    	Revision ID	0xA1
DMI
DMI BIOS
    	vendor	Phoenix Technologies LTD
    	version	ASUS P5N-T DELUXE ACPI BIOS Revision 1501
    	date	08/05/2009
    	ROM size	1024 KB
DMI System Information
    	manufacturer	ASUSTeK Computer INC.
    	product	P5N-T DELUXE
    	version	System Version
    	serial	System Serial Number
    	UUID	{1E00F940-008C-BD00-A293-E0CB4E065023}
    	SKU	unknown
    	family	unknown
DMI Baseboard
    	vendor	ASUSTeK Computer INC.
    	model	P5N-T DELUXE
    	revision	1.XX
    	serial	123456789000
DMI System Enclosure
    	manufacturer	Chassis Manufacture
    	chassis type	Desktop
    	chassis serial	EVAL
DMI Processor
    	manufacturer	Intel
    	model	Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
    	clock speed	2500.0 MHz
    	FSB speed	333.0 MHz
    	multiplier	7.5x
DMI Port Connector
    	designation	PRI_IDE (internal)
    	connector	On Board IDE
DMI Port Connector
    	designation	FLOPPY (internal)
    	port type	8251 FIFO Compatible
    	connector	On Board Floppy
DMI Port Connector
    	designation	COM1 (internal)
    	port type	Serial Port 16450
    	connector	9 Pin Dual Inline (pin 10 cut)
    	connector	DB-9 male
DMI Port Connector
    	designation	PS/2 Keyboard (internal)
    	port type	Keyboard Port
    	connector	PS/2
    	connector	PS/2
DMI Port Connector
    	designation	PS/2 Mouse (internal)
    	port type	Mouse Port
    	connector	PS/2
    	connector	PS/2
DMI Port Connector
    	designation	USB1 (external)
    	port type	USB
DMI Port Connector
    	designation	USB2 (external)
    	port type	USB
DMI Port Connector
    	designation	USB3 (external)
    	port type	USB
DMI Port Connector
    	designation	USB4 (external)
    	port type	USB
DMI Port Connector
    	designation	USB5 (external)
    	port type	USB
DMI Port Connector
    	designation	USB6 (external)
    	port type	USB
DMI Port Connector
    	designation	USB7 (external)
    	port type	USB
DMI Port Connector
    	designation	USB8 (external)
    	port type	USB
DMI Port Connector
    	designation	USB9 (external)
    	port type	USB
DMI Port Connector
    	designation	USB10 (external)
    	port type	USB
DMI Port Connector
    	designation	LINE_IN (internal)
    	designation	LINE_IN (external)
    	port type	Audio Port
DMI Port Connector
    	designation	Back Surround L/R (internal)
    	designation	Back Surround L/R (external)
    	connector	Mini Jack (headphones)
DMI Port Connector
    	designation	Side Surround L/R (internal)
    	designation	Side Surround L/R (external)
DMI Port Connector
    	designation	Center/LFE (internal)
    	designation	Center/LFE (external)
DMI Port Connector
    	designation	CD_IN (internal)
    	designation	CD_IN (external)
    	connector	On Board Sound Input From CD-ROM
DMI Port Connector
    	designation	SPDIF_01 (external)
DMI Port Connector
    	designation	SPDIF_02 (external)
DMI Port Connector
    	designation	LAN_1 (external)
    	port type	Network Port
    	connector	RJ-45
DMI Port Connector
    	designation	IE1394_1 (external)
    	port type	Firewire (IEEE P1394)
    	connector	IEEE 1394
DMI Port Connector
    	designation	IE1394_2 (external)
    	connector	IEEE 1394
DMI Port Connector
    	designation	SATA1 (internal)
DMI Port Connector
    	designation	SATA2 (internal)
DMI Port Connector
    	designation	SATA3 (internal)
DMI Port Connector
    	designation	SATA4 (internal)
DMI Port Connector
    	designation	SATA5 (internal)
DMI Port Connector
    	designation	SATA6 (internal)
DMI Port Connector
    	designation	ESATA (internal)
DMI Port Connector
    	designation	CHASSIS (internal)
DMI Port Connector
    	designation	AUDIO1 (internal)
DMI Port Connector
    	designation	CPU_FAN1 (internal)
DMI Port Connector
    	designation	PWR_FAN1 (internal)
DMI Port Connector
    	designation	CHA_FAN1 (internal)
DMI Port Connector
    	designation	CHA_FAN2 (internal)
DMI Extension Slot
    	designation	PCI1
    	type	PCI
    	width	32 bits
    	populated	no
DMI Extension Slot
    	designation	PCIEX16_1
    	type	A5
    	populated	no
DMI Extension Slot
    	designation	PCIEX16_2
    	type	A5
    	populated	no
DMI Extension Slot
    	designation	PCIEX16_3
    	type	A5
    	populated	yes
DMI Extension Slot
    	designation	PCIEX1_1
    	type	A5
    	populated	no
DMI Extension Slot
    	designation	PCIEX1_2
    	type	A5
    	populated	no
DMI Physical Memory Array
    	location	Motherboard
    	usage	System Memory
    	correction	None
    	max capacity	128 MBytes
    	max# of devices	4
DMI Memory Device
    	designation	DIMM_A1
    	format	DIMM
    	type	unknown
    	size	2048 MBytes
DMI Memory Device
    	designation	DIMM_A2
    	format	DIMM
    	type	unknown
    	size	2048 MBytes
DMI Memory Device
    	designation	DIMM_B1
    	format	DIMM
    	type	unknown
    	size	2048 MBytes
DMI Memory Device
    	designation	DIMM_B2
    	format	DIMM
    	type	unknown
    	size	2048 MBytes
Graphics
Number of adapters	1
Graphic APIs
API	NVIDIA I/O
API	NVIDIA NVAPI
Display Adapters
Display adapter 0
    	Name	NVIDIA GeForce 9600 GSO 512
    	Revision	A1
    	Codename	G94
    	Technology	65 nm
    	Memory size	768 MB
    	Memory bus width	192 bits
    	PCI device	bus 7 (0x7), device 0 (0x0), function 0 (0x0)
    	Vendor ID	0x10DE (0x3842)
    	Model ID	0x0625 (0xC961)
    	Performance Level	0
        	 Core clock	600.0 MHz
        	 Shader clock	1500.0 MHz
        	 Memory clock	400.0 MHz
Win32_VideoController	AdapterRAM = 0x30000000 (805306368)
Win32_VideoController	DriverVersion = 9.18.13.3158
Win32_VideoController	DriverDate = 10/15/2013
Software
Windows Version	Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
DirectX Version	11.0
Just create a sig. w/ your system spec's, as 99% of that information is useless to us. For example...
Code:
MB: Asus P5N-T DELUXE
CPU: Q9300
RAM: 8GB (4 x 2GB) Corsair DDR2-800 (5-5-5-18 at 1.80v)
OS: Win7 SP1 x64
Video:
PSU:
... etc.
Sorry man i have no idea what im doing i just want better fps in games i play >.< also thanks for making it easyer 2 read :p
Click the "quick links" link at the top of the page and select Edit Signature. There you can enter your system spec's, so that your components are listed in each of your posts. That way whenever you post a question related to your system, we don't have to ask "what are your system spec's" each time, and you don't have to keep re-entering them. And if you're interested in learning about overclocking your quad, then give this thread a read...
HOWTO: Overclock C2Q (Quads) and C2D (Duals) - A Guide v1.1
http://www.overclockers.com/forums/showthread.php?t=515316
imo first and best option, is to find a another Q9000 cpu. the Q9300 has the lowest multi and wont allow much overclocking on that NV based board. you might get lucky to hit 400mhz fsb on that board with the quad. considering the NV780i is a rebadged NV680i board sporting a NF200 pcie 2.0 buss chip.
may not have much money but ebay is a great place to find decent prices on cpus. if anything i would higher suggest even looking for a 65nm Q6600 (SLACR=G0 aka the better ocing Q6600). you may have even better luck ocing it vs some of the 45nm parts on that board.
