I've googled around a bit but havent found any software i'm comfy with useing...
issues i'd like to address or tweak..
bandwidth shareing... I have a mouse, 2 flash drives and a wifi adapter on 3 diffrent banks of my dell b110 =D lol yea i know.. but its all i got right now.
From what i've read and know of how usb functions.. it won't matter where or how i hook em up... they share bandwidth and cpu cycles...
I would like the wifi and flash sticks to have priority.
Flash sticks.. I would like the fastest possible bandwidth for these without burning them out.. I noticed they get pretty hot so i've taken them out of the plastic caseings.. i can give u the numbers off the chipsets if it will help out.. I'm considering placeing a fan near them for cooling since they still get over 90*f at times.. I use them for virtual memory. the blinking lights says they are being used...but its usually a last resort after it's used the 2gb's i've setup on 2 HD's.. but the memory transfers and allocation seem to be pretty much instant with them on then without.. I'm still testing things out though..
for some reason they are using generic microsuck drivers, and are labeled "generic volumes" as well...
USB flash #1 2gb random xmas gift benchmarks toshiba chipset
Performance Test 16 KB : 510 operations/min. (1157.59 KB/s)
Performance Test 32 KB : 330 operations/min. (1146.59 KB/s)
Performance Test 64 KB : 330 operations/min. (1149.41 KB/s)
Performance Test 128 KB : 330 operations/min. (1021.62 KB/s)
Performance Test 256 KB : 330 operations/min. (1005.19 KB/s)
Performance Test 512 KB : 252 operations/min. (1026.14 KB/s)
Performance Test 1024 KB : 290 operations/min. (916.66 KB/s)
Performance Test 2048 KB : 288 operations/min. (955.27 KB/s)
Usb flash #2 512mb random b-day gift unknown chipset
Performance Test 16 KB : 63666 operations/min. (1167.98 KB/s)
Performance Test 32 KB : 3692 operations/min. (1072.97 KB/s)
Performance Test 64 KB : 3816 operations/min. (1192.47 KB/s)
Performance Test 128 KB : 1392 operations/min. (855.75 KB/s)
Performance Test 256 KB : 1550 operations/min. (1009.22 KB/s)
Performance Test 512 KB : 966 operations/min. (998.34 KB/s)
Performance Test 1024 KB : 780 operations/min. (978.97 KB/s)
Performance Test 2048 KB : 918 operations/min. (968.62 KB/s)
Is it possible to get them over 48mhz???
Device Information :
Device : 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1
Version : 1.0
Interface : UHCI
Frequency : 48 MHz
Device : 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2
Version : 1.0
Interface : UHCI
Frequency : 48 MHz
Device : 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4
Version : 1.0
Interface : UHCI
Frequency : 48 MHz
Device : 82801EB/ER (ICH5/ICH5R) USB 2.0 EHCI Controller
Version : 2.0
Interface : EHCI
General Information :
Type : Intel Pentium 4
Internal Specification : Intel(R) Pentium(R) 4 CPU 2.80GHz
Codename : Northwood
Revision : D1
Technology : 0.13µ
CPU ID : F.2.9
CPU IDEx : F.2.9
Brand ID : 9
Microcode : MU0F292E
Instructions :
IA-64 Technology : No
Intel64 (EM64T) : No
AVX : No
FPU128 : No
SSE5 : No
SSE4a : No
SSE4.2 : No
SSE4.1 : No
S-SSE3 : No
SSE3 : No
SSE2 : Yes
SSE : Yes
Extended 3DNow! Technology : No
3DNOW Prefetch : No
3DNow! Pro Technology : Yes
AMD MMX Technology : No
MMX Technology : Yes
Cyrix MMX Technology : No
FMA : No
AES : No
OSXSAVE : No
MOVBE : No
PCLMULQDQ : No
CLF - Cache Line Flush : Yes
CX8 - CMPXCHG8B : Yes
CX16 - CMPXCHG16B : No
CMOV - Conditionnal Move Inst. : Yes
MON - Monitor/Mwait : No
POPCNT : No
RDTSCP : No
SEP - Fast System Call : Yes
Miscellaneous :
XD - No-execute Page : No
VT - Vanderpool Technology : No
TXT - Trusted Execution Techno... No
SVM - Secure Virtual Machine : No
FPU - Co-processor Built-in : Yes
FXSR - Fast Float Save & Restore : Yes
xTPR - Send Task Priority : Yes
DAZ - Denormals Are Zero : Yes
FFXSR : No
LAHFSAHF : No
CMPLEGACY : No
ALTMOVCR8 : No
ExtApicSpace : No
PBE - Pend. Brk. EN. : No
LAHF - LAHF/SAHF Inst. : No
ABM : No
MASSE - Misaligned SSE : No
OSVW - OS Visible Workaround : No
IBS : No
P1GB - 1GB Page Size : No
SKINIT, STGI, DEV : No
WDT - Watchdog Timer : No
Features :
x2APIC : No
APIC - Local APIC Built-in : Yes
VME - Virtual Mode Ext. : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
MTRR - Memory Type Range Reg. : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
DS - Debug Trace & EMON Store : Yes
SS - Self Snoop : Yes
ACPI - Software Clock Control : Yes
TM - Thermal Monitor : Yes
TM2 - Thermal Monitor 2 : No
EST - Enhanced SpeedStep Tec... No
HTT - Hyper-Threading : Yes
SBF - Signal Break on FERR : Yes
DSCPL - CPL qualified Debug Store : No
CID - Context ID : Yes
LT - LaGrande Technology : No
PDCM : No
DCA - Direct Cache Access : No
EPS - Enhanced PowerSaver : No
Features Hyper-Threading :
Technology : No
Advanced Settings :
In Order Queue Depth : 12
Fast-Strings : Yes
x87 FPU Opcode : No
Split-Lock : Yes
Performance Monitoring : Yes
Prefetch Queue : Yes
Branch Trace Storage : Yes
C1E - Enhanced Halt State : No
Mainboard Upgradeability :
Socket/Slot : Microprocessor
Upgrade interface : ZIF Socket
Supported Speed : 3600 MHz (or more)
Supported Voltage : 1.1V
NorthBridge : Intel i865GV
SouthBridge : 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge
NorthBridge Information :
Architecture : HUB
Manufacturer : Intel (Dell Computer Corp)
Codename : Springdale
Revision : A2
Bus Speed : 154.3 MHz
FSB Frequency : 617.3 MHz (QDR)
PAT Enabled : Unspecified
FSB max. Support : 800 MHz
RAM max. Support : DDR (400 MHz)
Memory Information :
Type : DDR-SDRAM PC3100
Frequency : 192.9 MHz
DRAM/FSB Ratio : 5/4
Supported Channels : Dual (128-bit)
Activated Channels : Single
ECC Diagnostic : No
CAS Latency (tCL) : 3 clocks
RAS to CAS (tRCD) : 4 clocks
RAS Precharge (tRP) : 4 clocks
Cycle Time (tRAS) : 10 clocks
Shared Memory (video) : Yes
Bus Information :
AGP enabled : No
Video Information :
Integrated Controller : Yes
Enabled : Yes
Frame Buffer : 8192 KB
APIC Information :
Version : 2.00
Maximum Interrupts : 24
IRQ Handler enabled : Yes
Hub Interface Information :
Version : 1.00
Time Slice : 0
Width : 8-bit
Full Duplex : Yes
Frequency : 4x (264 MHz)
Multiplier : 1/1x
Device Capabilities (PCI) :
I/O Access : No
Memory Access : Yes
Bus Master Capable : Yes
Special Cycle Recognition : No
Memory Write & Invalidate : No
VGA Palette Snoop : No
Parity Error Response : No
Cycle Wait : No
System Error Line : Yes
Fast Back-to-Back : No
Detects Parity Errors : No
User Defined Format : No
PCI 66Mhz Bus Support : No
New Capability List : Yes
PCI Support : Vendor-Dependant
Version : 1.0
Interface : UHCI
Frequency : 48 MHz
Version : 1.0
Interface : UHCI
Frequency : 48 MHz
Version : 1.0
Interface : UHCI
Frequency : 48 MHz
Version : 2.0
Interface : EHCI
Revision : D1
Technology : 0.13µ
CPU ID : F.2.9
CPU IDEx : F.2.9
Brand ID : 9
Instructions :
AVX : No
FPU128 : No
SSE5 : No
SSE4a : No
SSE4.2 : No
SSE4.1 : No
S-SSE3 : No
SSE3 : No
SSE2 : Yes
SSE : Yes
3DNOW Prefetch : No
FMA : No
AES : No
OSXSAVE : No
MOVBE : No
PCLMULQDQ : No
POPCNT : No
RDTSCP : No
Miscellaneous :
FFXSR : No
LAHFSAHF : No
CMPLEGACY : No
ALTMOVCR8 : No
ExtApicSpace : No
ABM : No
IBS : No
Features :
x2APIC : No
PDCM : No
Technology : No
Advanced Settings :
Fast-Strings : Yes
x87 FPU Opcode : No
Split-Lock : Yes
Architecture : HUB
Revision : A2
ECC Diagnostic : No
Bus Information :
AGP enabled : No
Video Information :
Enabled : Yes
APIC Information :
Version : 2.00
Version : 1.00
Time Slice : 0
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
I/O Access : No
Memory Access : Yes
Cycle Wait : No
