well it been a routine of 3 years to upgrade my computer and im coming around again to upgrade certain parts.
Im currently using
1gb of Corsair XMS DDR400
Asus SLI Deluxe socket 939
AMD 3000+ 64
and a 6800gs
basically the budget build that has both power and performance back then.
My power supply is a 550watt antec give or take that it is now still good or underpowered due to increase of power consumption.
so i was wondering what kind of CPU would fit in the slot of budget right now but offer performance at the same time. I think the Q6600 is good but is a tad expensive.
trend ive gone through amd 2500+ and 9500pro ----> intel 2.4c and 9800 unlocked ----> amd 64 3000 and 6800gs.
so i was wondering what kind of motherboard/ram/cpu/graphic card combo would work in that i can overclock and get performance to price wise.
Friend just got his xps 1730 with dual 8800gtx and it producing some fine frame rates and i just want to be able to get more than 20 frame rate since i upgraded from my 19inch viewsonic to a 24inch dell. increasing from 1280x1240 to 1900x1200.
Im currently using
AMD 3000+ 64
and a 6800gs
