I thought this would be better if I re-posted this in this section for a little more traffic.
I have been messing with my cooling, and was thinking on overvolting my fans by a little bit. I was wondering how the wattage rating is calculated when combining positive and negative electrical potentials.
I run 4 fans controlled by Speedfan, off a "Hi power fan controller"
Intake 120mm Adda .44a 5.2w
Exhaust 80mm Sunon .17a 2.1w
CPU Dual Delta blowers .85a 10.2w ea
My power supply is 450w
+5v -5v +12v -12v +3.3v +5vsb
34a 0.5a 18a 0.8a 25a 2a
170w 2.5w 216w 9.6w 82.5w 10w
If I choose 15.3v as my overvolt, my choices are using:
3.3v (82.5w) with the -12v (9.6w)
or -12v with +3.3v
Is the power rating, the combined rating of the OV rails used?
eg. [email protected] + (-12v)@9.6w = [email protected]
Or, is the max power rating usable, based upon the lowest rating of the individual rails used. eg. 9.6w of the -12v rail.
Does it make any difference having the higher wattage rating on the positive lead of the fan?
Thanks
Paul
or -12v with +3.3v
Thanks
Paul
