will this PSU power my 4890
kaitlin4599
hello i need to know if the psu i have will power my HD 4890 gpu i cant buy a better psu untill next months when i get paid as im on dissability heres the specs for the psu btw since the 4890 requires 2 6 pin pcie and since my psu has only 1 6 pin pcie im using a molex to pcie 6 pin adapter to power the gpu all i need to know is will this psu work with my video card for gaming and surfing the net untill i can buy a better more stronger psu
Model
Brand
Antec
Model
EA380
Series
earthwatts
Spec
Type
ATX12V v2.0
Maximum Power
380W Continuous Power
Fans
1 x 80mm low noise cooling fan
PFC
Active
Main Connector
20+4Pin
+12V Rails
2
PCI-Express Connector
1 x 6-Pin
SATA Power Connector
2
SLI
No
CrossFire
No
Modular
No
Efficiency
> 80%
Energy-Efficient
80 PLUS Certified
Input Voltage
100 - 240 V
Input Frequency Range
50/60 Hz
Input Current
6A
Output
+3.3V@20A,+5V@20A,+12V1@17A,+12V2@17A,[email protected],[email protected]
Approvals
UL, CUL, FCC, TUV, CE, CB, C-tick, CCC
HD4890 from XFX and i cant purchase a new psu till next month as im on dissability and dont get paid for another 2 weeks i also bought a 2 molex to 6 pin pcie adapter as well
nope cpu is at the stock 3.01Ghz also heres a link to the psu i have
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371005
i bought a 650 watt psu off ebay new in the box and it keeps shutting off when i play games so i wanted to know if the earthwatts psu io have as a spare would power my settup till i can afford a new psu in case you need more info i am running an athlon 64 x2 6000+ 125 watt cpu 1 1TB standard sata hard drive 1 sata dvd rom and 1 80mm led side cooling fan for the case and 4 1 gig ddr2 800 mhz memory sticks
will it allow me to play games even with all the other stuff i have being powered by said psu
Antec is a good PSU. My brother has the exact model PSU you have, which is powering his AMD 7770 gpu.
