- Sep 2, 2002
- Haiku, Maui
Ok, I've been reading the advice about PSU's on this and other forums. I am building a box with a P4P800-deluxe running a p4 [email protected]. Trouble is the PSU's I have around the house just won't hack it. I started by using a no-name 300W PSU with a 10amp 12volt line and it was fine for a couple of days and then just refused to boot; an on again off again thing. Dead at the switch.
Changed to an Enermax 330W with 12amps on the 12volt rail and still nothing. Used an Antec 300w with 10 amps on th 12volt line and I get a start but stops right away. This is with the board on the bench stripped down without anything: just trying to make the cpu fan whir.
So I'm trying to buy a new PSU. I live in a small pueblo in southeren Spain and the choices are not overwhelming. All they talk about here are watts. The shops I visited normally sell a 350watt psu for a P4. So I asked to have a look at it and it has 120 watts on the 3.3 and 5v rails and 10amps on the 12volt rail. So I was like: "ugh, no way".
I have left an all points bulletin search order for a PSU with 15-20 amps on the 12volt rail and about 200wattts on the 3.3 and 5volt rails. My question is: Does it matter the wattage of the psu (350, 400, 420, 500, 550) as long as the above characteristics are met? Or are the figures I am looking for too low if it's, say, a 600watt PSU?
thanks.
thanks.
