- May 9, 2004
- Little Rock, AR
neoraistlin said:I was browsing the forums and this looked like a good place to post my question. I am in the market for a major computer upgrade. I want a gaming rig that can handle 250 FSB with 1:1 2.5-3-3-6 timings.
Right now I have my eye on an Asus P4P800-SE mobo, PC4000 Ram dual kit from corsair: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85017-14, and a P4 3.0 C.
I had a couple of questions:
1. I see most OCers going for 2.4 C and 2.8 C and I have read the articles associated with both...but since the 3.0 C is still the same core shouldn't it OC the same? To sum it up is the 3.0 C a good choice for my desired outcome?
2. Does this setup have a high probability of working at my desired speeds (I know OCing has a lot to do with the luck of the draw on the processor)
3. Does this mobo have locked AGP/PCI?
Thanks for the help guys and Clock On!
Right now I'm running a P4C800-E Deluxe board at 250FSB with a 3.0E @ 1:1 2.5-3-3-6. All the specs are in my sig. It seems to be a pretty good setup. You just have to hope you get a good proc, that motherboard your talking about should be fine. And I'm not sure if I would go with that corsair ram if I were you. I hear the 4200 Adata Hyperram is good, so is the OCZ 3700EB if you only plan on going to 250FSB.
